Tengo una duda y es la siguiente lo que sucede es que quiero que mi servo cuando lo leo con mi joystick, digamos los posiciono al máximo de y pero el servo cuando suelto mi joystick se devuelve solo quisiera que guardara su posición hasta que yo le indique con mi joystick que debe volver. Agradecería la ayuda
Hi Juan,
I use Google translate to get below
I have a question and the following is what happens is that I want my servo when I read it with my joystick, let’s say I position them to the maximum of and but the servo when I release my joystick is returned I just want it to save its position until I indicate with my joystick it must come back. I would appreciate the help
If you would like to keep the position, you need to constantly output the PWM signal to the servo, if you can share your platform and servo component, that’d be helpful.
