Hi all, I’m new in this forum and I hope I can learn from You all because I started just some months ago to code. What I am doing is testing more microcontrollers to find the best solution. However, right now, because I am quite a rookie, I am in trouble to complete a code. I hope that you can help me to write the proper code.
I am using a mbed OS. This is a portenta h7 of Arduino. It has to restore the offset of an IMU sensor.
My problem is to emulate the eeprom. I would like to access to the memory of my board, save the calibration of the sensor and store them at the next power-on.
Hoping that someone of You could spend a moment for me to modify this code, I attach the code that I used with a controller with E2PROM integrated.
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
#include <EEPROM.h>
/* Set the delay between fresh samples */
#define BNO055_SAMPLERATE_DELAY_MS (100)
// Check I2C device address and correct line below (by default address is 0x29 or 0x28)
// id, address
Adafruit_BNO055 bno = Adafruit_BNO055(55, 0x28);
Displays some basic information on this sensor from the unified
sensor API sensor_t type (see Adafruit_Sensor for more information)
void displaySensorDetails(void)
sensor_t sensor;
bno.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print("Sensor: "); Serial.println(sensor.name);
Serial.print("Driver Ver: "); Serial.println(sensor.version);
Serial.print("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print("Max Value: "); Serial.print(sensor.max_value); Serial.println(" xxx");
Serial.print("Min Value: "); Serial.print(sensor.min_value); Serial.println(" xxx");
Serial.print("Resolution: "); Serial.print(sensor.resolution); Serial.println(" xxx");
Serial.println("");
delay(500);
Display some basic info about the sensor status
void displaySensorStatus(void)
/* Get the system status values (mostly for debugging purposes) */
uint8_t system_status, self_test_results, system_error;
system_status = self_test_results = system_error = 0;
bno.getSystemStatus(&system_status, &self_test_results, &system_error);
/* Display the results in the Serial Monitor */
Serial.println("");
Serial.print("System Status: 0x");
Serial.println(system_status, HEX);
Serial.print("Self Test: 0x");
Serial.println(self_test_results, HEX);
Serial.print("System Error: 0x");
Serial.println(system_error, HEX);
Serial.println("");
delay(500);
Display sensor calibration status
void displayCalStatus(void)
/* Get the four calibration values (0..3) */
/* Any sensor data reporting 0 should be ignored, */
/* 3 means 'fully calibrated" */
uint8_t system, gyro, accel, mag;
system = gyro = accel = mag = 0;
bno.getCalibration(&system, &gyro, &accel, &mag);
/* The data should be ignored until the system calibration is > 0 */
Serial.print("\t");
if (!system)
Serial.print("! ");
/* Display the individual values */
Serial.print("Sys:");
Serial.print(system, DEC);
Serial.print(" G:");
Serial.print(gyro, DEC);
Serial.print(" A:");
Serial.print(accel, DEC);
Serial.print(" M:");
Serial.print(mag, DEC);
Display the raw calibration offset and radius data
void displaySensorOffsets(const adafruit_bno055_offsets_t &calibData)
Serial.print("Accelerometer: ");
Serial.print(calibData.accel_offset_x); Serial.print(" ");
Serial.print(calibData.accel_offset_y); Serial.print(" ");
Serial.print(calibData.accel_offset_z); Serial.print(" ");
Serial.print("\nGyro: ");
Serial.print(calibData.gyro_offset_x); Serial.print(" ");
Serial.print(calibData.gyro_offset_y); Serial.print(" ");
Serial.print(calibData.gyro_offset_z); Serial.print(" ");
Serial.print("\nMag: ");
Serial.print(calibData.mag_offset_x); Serial.print(" ");
Serial.print(calibData.mag_offset_y); Serial.print(" ");
Serial.print(calibData.mag_offset_z); Serial.print(" ");
Serial.print("\nAccel Radius: ");
Serial.print(calibData.accel_radius);
Serial.print("\nMag Radius: ");
Serial.print(calibData.mag_radius);
Arduino setup function (automatically called at startup)
void setup(void)
Serial.begin(115200);
delay(1000);
Serial.println("Orientation Sensor Test"); Serial.println("");
/* Initialise the sensor */
if (!bno.begin())
/* There was a problem detecting the BNO055 ... check your connections */
Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
while (1);
int eeAddress = 0;
long bnoID;
bool foundCalib = false;
EEPROM.get(eeAddress, bnoID);
adafruit_bno055_offsets_t calibrationData;
sensor_t sensor;
* Look for the sensor's unique ID at the beginning oF EEPROM.
* This isn't foolproof, but it's better than nothing.
if (bnoID != sensor.sensor_id)
Serial.println("\nNo Calibration Data for this sensor exists in EEPROM");
delay(500);
else
Serial.println("\nFound Calibration for this sensor in EEPROM.");
eeAddress += sizeof(long);
EEPROM.get(eeAddress, calibrationData);
displaySensorOffsets(calibrationData);
Serial.println("\n\nRestoring Calibration data to the BNO055...");
bno.setSensorOffsets(calibrationData);
Serial.println("\n\nCalibration data loaded into BNO055");
foundCalib = true;
delay(1000);
/* Display some basic information on this sensor */
displaySensorDetails();
/* Optional: Display current status */
displaySensorStatus();
/* Crystal must be configured AFTER loading calibration data into BNO055. */
bno.setExtCrystalUse(true);
sensors_event_t event;
bno.getEvent(&event);
/* always recal the mag as It goes out of calibration very often */
if (foundCalib){
Serial.println("Move sensor slightly to calibrate magnetometers");
while (!bno.isFullyCalibrated())
delay(BNO055_SAMPLERATE_DELAY_MS);
else
Serial.println("Please Calibrate Sensor: ");
Serial.print("X: ");
Serial.print(event.orientation.x, 4);
Serial.print("\tY: ");
Serial.print(event.orientation.y, 4);
Serial.print("\tZ: ");
Serial.print(event.orientation.z, 4);
/* Optional: Display calibration status */
displayCalStatus();
/* New line for the next sample */
Serial.println("");
/* Wait the specified delay before requesting new data */
Serial.println("\nFully calibrated!");
Serial.println("--------------------------------");
Serial.println("Calibration Results: ");
adafruit_bno055_offsets_t newCalib;
bno.getSensorOffsets(newCalib);
displaySensorOffsets(newCalib);
Serial.println("\n\nStoring calibration data to EEPROM...");
eeAddress = 0;
bnoID = sensor.sensor_id;
EEPROM.put(eeAddress, bnoID);
EEPROM.put(eeAddress, newCalib);
Serial.println("Data stored to EEPROM.");
Serial.println("\n--------------------------------\n");
delay(500);
void loop() {
/* Get a new sensor event */
/* Display the floating point data */
displayCalStatus();
/* Optional: Display sensor status (debug only) */
//displaySensorStatus();
Serial.println("");
