When using MBedOS in SAMR34 Xplained Pro with the following LoRa configuration I am facing the issue with enabling PABoost
Configuration used::
- Transmission Type : OTAA
- ADR : Disabled
- Data Rate : Set to DR_0
- Delay B/W Transmissions : 0
- Frequency Band : IN865
- Payload Size : 10Bytes
- N/W Server : Chirp Stack
Observations::
- Not able to figure out whether the PABoost is enabled or not
- The RSSI values are around -70 to -90 and not changed even after the rf-switch pin is toggled
How can we enable PABoost in SAMR34 with MBedOS??
