How to keep the orientation from a yost 3 space-sensor through a mbed system
Hi All,
I would like to extract euler angles coming from sensor coming from YostLab, TSS-EM.
This is the manual:
What I am trying to do is to connect to a portenta H7 and keep the orientation through SPI communication.
The issue is that I am not able to reach my aim. Searching online I found something for the AVR system. I tried to adapt on mbed without any success.
Here is the code:
#include<SPI.h>
#include<stdlib.h>
#define TRANSACTION_SETTINGS SPISettings(1000000,MSBFIRST,SPI_MODE0)
#define SS 7
#define Serial _UART_USB_
// Extra pins for use with the level shifter
//#define OE 7
//#define Vout 9
//these are the most reliable delays tested
#define MicroDelay 6
#define MiliDelay 3
/*Spi Command List:
  0xE9: This command prepares the sensor to receive a TSS command
  0xD9: This command will clear the command stored in the sensor
  0x69: This command tells the sensor to return the command data
  0x81: This command prepares the sensor to send the status of the slave device
  more information in data sheet page 23 */
void setup() {
  _UART_USB_.begin(57600);
  _UART_USB_.println("step0");
  SPI.begin();
  // pinMode(OE, OUTPUT);
  // digitalWrite(OE, HIGH);
  // pinMode(Vout, OUTPUT);
  // digitalWrite(Vout, HIGH);
  pinMode(SS, OUTPUT);
  digitalWrite(SS, HIGH);
  _UART_USB_.println("step1");
  SPI.beginTransaction(TRANSACTION_SETTINGS);
  _UART_USB_.println("step2");
  Read_UART_USB_Number();
  _UART_USB_.println("step3");
void loop() {
  //print out tared orientation every half second
  delay(500);
  ReadOrientationQuat();
void Read_UART_USB_Number() {
  char buff[32];
  digitalWrite(SS, LOW);
  SPI.transfer(0xe9); //tell the sensor the next byte will be a command
  delayMicroseconds(MicroDelay);
  SPI.transfer(0xed); //command to get _UART_USB_ Number of sensor
  delay(MiliDelay);
  unsigned char in_byte[5];
  unsigned char polling_byte = 0x00;
  //Poll the sensor until it returns the return data length in this case it will be 4
  while (polling_byte != 4) {
    polling_byte = SPI.transfer(0x69);
    delay(MiliDelay);
  //Read out requested command data
  for (unsigned int i = 0; i < polling_byte; i++) {
    in_byte[i] = SPI.transfer(0xff);
  sprintf(buff, "%02x%02x%02x%02x", in_byte[0], in_byte[1], in_byte[2], in_byte[3]);
  _UART_USB_.println(buff);
  _UART_USB_.println("done");
void ReadOrientationQuat() {
  char buff[32];
  byte in_byte[16];
  SPI.transfer(0x00); //command to get tared orientation in quaternion form
  delay(MiliDelay);
  while (polling_byte != 16) {
    delay(MiliDelay);
  for (unsigned int i = 0; i < polling_byte; ++i) {
  for (unsigned int i = 0; i < 4; ++i) {
    //reverse endianess and append to string
    ((float*)in_byte)[i] = ReverseFloat(((float*)in_byte)[i]);
    dtostrf(((float*)in_byte)[i], 8, 5, (buff + (i * 8 + i)));
    if (i * 8 + i - 1 < 32 && i) {
      buff[i * 8 + i - 1] = ',';
float ReverseFloat( const float inFloat )
  float retVal;
  char *floatToConvert = ( char* ) & inFloat;
  char *returnFloat = ( char* ) & retVal;
  // swap the bytes into a temporary buffer
  returnFloat[0] = floatToConvert[3];
  returnFloat[1] = floatToConvert[2];
  returnFloat[2] = floatToConvert[1];
  returnFloat[3] = floatToConvert[0];
  return retVal;
char *dtostrf (double val, signed char width, unsigned char prec, char *sout) {
  char fmt[20];
  sprintf(fmt, "%%%d.%df", width, prec);
  sprintf(sout, fmt, val);
  return sout;
Can someone have a look and guide me to the solution please?
But that is Arduino code not Mbed code. So, where is your Mbed code? We can’t fix something that can’t be seen.
Page 29 of your datasheet seems like a good starting point with SPI - API references and tutorials | Mbed OS 6 Documentation
Br, Jan
If this is the first time you are using the Portenta board with Mbed, I would suggest to start with a basic “Hello World!” program. Forget about SPI and communicating with the sensor. Just get printing a simple message to the serial/USB port working. Then build up from that.
