MAX32630FTHR cannot flash firmware via DAPLink FAIL.TXT: transfer timed out
Hello everyone,
I am using a MAX32630FTHR board with a MAX32625PICO / DAPLink adapter to flash firmware through the 10-pin SWD/JTAG ribbon cable.
My setup is:
  • Board: MAX32630FTHR
  • Programmer: MAX32625PICO / DAPLink
  • Connection: PC → DAPLink adapter → 10-pin ribbon cable → MAX32630FTHR
  • MAX32630FTHR is powered separately by USB/battery
  • VTref on J4 pin 1 to GND measures about 1.8V
  • DAPLINK drive appears normally on Windows
The problem is that every time I drag and drop a .bin firmware file to the DAPLINK drive, it creates a FAIL.TXT file with this error:
error: The transfer timed out.
type: transient, user
I tried flashing:
  • blinky_max32630fthr.bin
  • MAX86150EVSYS firmware .bin
  • A .bin compiled from Keil Studio Cloud for target max32630fthr
All give the same “transfer timed out” error.
I also tried:
  • Checking the 10-pin ribbon cable direction
  • Checking that the cable is not loose or shifted
  • Powering the MAX32630FTHR by USB
  • Pressing SW1 before flashing
  • Trying another DAPLink adapter
  • Measuring VTref on J4 pin 1, which is 1.8V
At the beginning, the MAX32630FTHR LED was lighting/blinking. After several failed flashing attempts, the LED stopped lighting. I also noticed that the 1.8V pin has voltage, but the 3.3V pin does not show voltage.
My questions are:
  1. Does VTref = 1.8V mean the MAX32630FTHR should still be programmable through SWD?
  2. Is “transfer timed out” usually caused by SWD communication failure, target reset issue, or DAPLink firmware mismatch?
  3. Is there a recommended recovery method for MAX32630FTHR, such as connect-under-reset or mass erase?
  4. Could the missing 3.3V rail be normal if the firmware/PMIC is not running, or does it indicate a hardware problem?
  5. If drag-and-drop DAPLink flashing fails, what is the recommended next step to recover the board?
Thank you very much for your help.
