Hi Jan,
are you sure about this effect of the reset() function? I did not see anything related in the code:
/** Reset CAN interface.
* To use after error overflow.
void can_reset(can_t *obj)
can_mode(obj, MODE_RESET);
HAL_FDCAN_ResetTimeoutCounter(&obj->CanHandle);
HAL_FDCAN_ResetTimestampCounter(&obj->CanHandle);
There is at least no obvious call to some frequency related setting. This is just a first impression from my side. Of course, this might be wrong.
In the meantime, I had a first look how the frequency settings are processed in the the function can_frequency() and in the CAN object initialization with default frequency of 100kHz.
For the NucleoG474RE the initialization is done within the function _can_init_freq_direct(can_t *obj, const can_pinmap_t *pinmap, int hz) which - apart from some pin mapping operations - performs some timing related calculations and applies general CAN settings.
In the function int can_frequency(can_t *obj, int f) also calculations are done but apparently with a focus to timing related settings.
So far so good.
There is a small difference in the timing calculations in both routines when determining the so called nominal prescaler:
_can_init_freq_direct(…):
// !When the sample point should be lower than 50%, this must be changed to
// !IS_FDCAN_NOMINAL_TSEG2(ntq/nominalPrescaler), since
// NTSEG2 and SJW max values are lower. For now the sample point is fix @75%
while (!IS_FDCAN_NOMINAL_TSEG1(ntq / nominalPrescaler)) {
nominalPrescaler ++;
if (!IS_FDCAN_NOMINAL_PRESCALER(nominalPrescaler)) {
error("Could not determine good nominalPrescaler. Bad clock value\n");
can_frequency(…):
// !IS_FDCAN_DATA_TSEG2(ntq/nominalPrescaler), since
while (!IS_FDCAN_DATA_TSEG1(ntq / nominalPrescaler)) {
When using this for a frequency of 100kHz, this leads to different settings for the nominalPrecaler and to all timing related settings.
- nominalPrescaler = 7 (_can_init_freq_direct)
- nominalPrescaler = 49 (can_frequency)
I am not familiar with CAN bus timings so far, but this does not look good.
Therefore, I changed the non-working code in can_frequency() to the working one in _can_init_freq_direct(),
i.e:
//while (!IS_FDCAN_DATA_TSEG1(ntq / nominalPrescaler)) {
Of course, applying a frequency of 100kHz now worked and did not “break” the transmissions any longer.
But also a change of the transmission frequency to 125kHz (on both sides: NucleoG474RE + LPC4088) led to working transmissions in my simple setup.
I used my workaround (IS_FDCAN_NOMINAL_TSEG1) now also in my application setup.
Now, the original issue is gone and I can perform the CAN bus transmissions from NucleoG474RE side with no errors (tested with 100kHz and 125kHz).
Many thanks, Jan, for your support! Your answers and suggestions made my day
Still, I try to understand why it works now and why the original code was written as it was - and how this could lead to the “symptoms” I first observed…
