Hi all, I am encountering a strange issue with my code. I am designing a state machine in a NUCLEO 410RB, and I am using a NEXTION NX8048T050 touch screen as a GUI for people to set certain parameters to be passed to the state machine.
Now state machine wise, I have not encountered any problems, however, the issue is that when I implement the Serial interrupt handler which consists of a few if statements, only the first if statement is processed. For example, if my code were like this:
void stop_handler(){
if (readbytes()==OPENED){
pc.printf("OPEN PRESSED");
if (readbytes()==CLOSED){
pc.printf("CLOSE PRESSED");
if (readbytes()==STARTED){
SPIN_SPD = parameters[0];
SPIN_DUR = parameters[1];
MAG_DUR = parameters[2];
MIX_DUR = parameters[3];
start_flag = true;
pc.printf("%d, %d, %d, %d\n", parameters[0], parameters[1], parameters[2], parameters[3]);
pc.printf("%d", start_flag);
if (readbytes()==CANCEL){
pc.printf("END");
I would only ever be able to see the ‘OPENED PRESSED’ message on my serial terminal, any other actions do not trigger any other messages. But if i were to rearrange it, for example:
start_flag = true;
pc.printf("END");
I would be able to start my machine proper, with the relevant messages showing. But I won’t be able to access the if statements if i pressed “OPEN” or “CANCEL”. Below is the main loop
// put your setup code here, to run once:
initialise();
prime_SM();
while(1) {
state_machine();
Below is the prime_SM function & initialise function
void prime_SM(){
NVIC_SetPriority(USART6_IRQn, 1);
Nextion.attach(stop_handler, Serial::RxIrq);
pc.printf("PRIMED\n");
void initialise(){
wait(2);
Nextion.puts(INITIALISE);
I would appreciate any insight to this
