TLS socket connect, none string based function
This produces string based API warning.
    virtual nsapi_error_t connect_socket(char *host, uint16_t port) {
    return ((TLSSocket*)_socket)->connect(host, port);
How would I change this for none string based?
Thank you
Paul
you need to construct a SocketAddress first and pass the SocketAddress to the connect():
    virtual nsapi_error_t connect_socket(const char *host, uint16_t port) {
      SocketAddress remote(host, port);
    return ((TLSSocket*)_socket)->connect(&remote);
Hi @star297
You could also look at the example:
  SocketAddress addr;
    result = net->gethostbyname("ifconfig.io", &addr);
    if (result != NSAPI_ERROR_OK) {
	printf("Error! DNS resolution for ifconfig.io failed with %d\n", result);
    addr.set_port(443);
    TLSSocket *socket = new TLSSocket;
    result = socket->open(net);
        printf("Error! socket->open() returned: %d\n", result);
        return result;
    socket->set_hostname("ifconfig.io");
    result = socket->set_root_ca_cert(cert);
        printf("Error: socket->set_root_ca_cert() returned %d\n", result);
        return result;
    result = socket->connect(addr);
        printf("Error! socket->connect() returned: %d\n", result);
        goto DISCONNECT;
This example, in addition to what was stated correctly by @JojoS, also set the CA root certificate and hostname for verification.
Thanks guy’s
I did think your snip would work Johannes, but I get this error.
Error: No matching member function for call to ‘connect’
Any suggestions?
BR
Paul
yes, sorry, connect takes a reference, not a pointer:
connect(remote);
hope this works.
Thank you Johannes,
Yes it did work, no warnings, however its impacted on another part that uses that function;
HttpsRequest* get_req = new HttpsRequest(socket, HTTP_GET, FirebaseUrl);
Error: Allocating an object of abstract class type ‘HttpsRequest’
After quite a long time :yawning_face: I managed to work it out;
Either this…
        SocketAddress addr;
        addr.set_port(port);
        return ((TLSSocket*)_socket)->connect(host);
or this;
        ((TLSSocket*)_socket)->set_hostname(host);
        SocketAddress addr;
        return ((TLSSocket*)_socket)->connect(addr);
I don’t know which method would be best. But as of today I have no warnings :joy:
Lets hope Mr. Takalo doesn’t have any more depreciating ideas! and focus on what is not currently working.
Thank’s to both of you for your help
Paul
