I am trying to use a WeAct Studio STM32H723VGT6 board. Into the Mbed Studio 1.4.5 I have selected the Nucleo-H723ZG and the GCC_ARM compiler. The link gives that following messages:
Unknown object name found in GCC map file: load address 0x0801cc48
Unknown object name found in GCC map file: load address 0x0801e428
Unknown object name found in GCC map file: load address 0x0801e488
Any idea ? The generated software seems to be well loaded via STM32 CubeProgrammer but it does not work into the target.
not sure if this is related but there were an issue with H723 and was fixed with this Pull Request #15407 , but it is in the master branch and not in any release version.
Hi Jan,
It is not related… link warning “Unknown object name found in GCC map file”. No idea about the cause. Mapping error somewhere? H723 was added end of 2022 to mbed with the gcc “only” limitation.
Alain
Building project mbed-os-example-blinky (NUCLEO_H723ZG, GCC_ARM)
Scan: mbed-os-example-blinky
Link: mbed-os-example-blinky
Elf2Bin: mbed-os-example-blinky
Module
.text
.data
.bss
[fill]
110(+0)
6(+0)
58(+0)
[lib]\c.a
46932(+0)
2474(+0)
89(+0)
[lib]\gcc.a
1920(+0)
0(+0)
0(+0)
[lib]\misc
188(+0)
4(+0)
28(+0)
[lib]\nosys.a
32(+0)
0(+0)
0(+0)
[lib]\stdc++.a
0(+0)
0(+0)
0(+0)
[misc]
0(+0)
0(+0)
0(+0)
main.o
1022(+0)
24(+0)
4954(+0)
mbed-os\cmsis
11118(+0)
168(+0)
6340(+0)
mbed-os\connectivity
5216(+0)
20(+0)
7241(+0)
mbed-os\drivers
3868(+0)
0(+0)
0(+0)
mbed-os\events
1692(+0)
0(+0)
3104(+0)
mbed-os\hal
1658(+0)
8(+0)
114(+0)
mbed-os\platform
5798(+0)
276(+0)
464(+0)
mbed-os\rtos
1298(+0)
0(+0)
8(+0)
mbed-os\targets
25876(+0)
12(+0)
1896(+0)
Subtotals
106728(+0)
2992(+0)
24296(+0)
Total Static RAM memory (data + bss): 27288(+0) bytes
Total Flash memory (text + data): 109720(+0) bytes
then this message comes from memmap.py tool that reads the mapfile and produces the memory sections overview. It does not affect the binary file and the messages can be ignored.
Ok. Extra test done. I have compiled (gcc) and downloaded the software into a STM32H743VIT6 board. No message and it works. Same software but H723… warning messages and nothing occurs into the WeAct Studio board. Strange.
Are you sure you are compiling for the correct target? The Nucleo has a H723ZG with 1 MB RAM, for the WeAct I see a version with H723VG with 564 kB RAM. There you need a different linker file, a H723ZG code will not run on a VG version.
No it is not the cause. STM32H723VGT6 and Nucleo-H723ZG are the same except the number of pins. In another project I am using a STM32H743VIT6 with the NUCLEO_H743ZI2 config and it works. When I compile in bare metal mode (as requested) no more link message. The STM32 CubeProgrammer work perfectly with the good cpu config. BUT the current is very low below 20 mA in despite of the red led active. Board failed ?
another problem can be a different clock source configuration, Nucleo boards usually use a clock input from the onboard STLink, the WeAct boards have a xtal.
for a basic test you can enforce the change of clock settings directly in the system_clock.c (first link)
ideal could be your own custom target settings for your target
you can modified current settings via mbed_app.json file. You need probably something like bellow, but fill correct value of your HSE. This settings will try to use HSE and if will failed then use HSI.
