Hello, I recently bought a 32x32 RGB LED matrix from Adafruit. For the Controller I decided to use an LPC1768. After installing the library (which is normally made for 16x32: https://os.mbed.com/teams/EIC_mbed/code/RGB_matrix_Panel/) it did not work. After doing some manipulation in the libraries and applying the following modules (see link: https://os.mbed.com/questions/5894/Add-updates-for-32x32/) I find myself with a half functional screen. Indeed you can see that the top part (16x32) works perfectly but it is impossible to display anything below this limit. And also it gives me a “mirror effect” on the unusable part and only in green color
. Could you explain to me what I did wrong and why it does not work?
