I am working with nucleo-f413 board. My project work normally without bootloader. I need to include bootloader to my board. I have also different project on custom board with STM32F429. Custom board has bootloader and works without a problem. I copied bootloader source to nucleo-f413 with appropriate settings. But after upload to nucleo-f413 board do not work. Board successfully start bootloader, but error
occurs when control is passed to main application.
No update found to apply
SD deinit
Starting application at addr: 134479872=MError Info ++
Error Status: 0x8001011D Code: 285 Module: 1
Error Message:
++ MbedOS Error Info ++
Error Value: 0x0
Current Thread: <unnamed> Id: 0x0 Entry: 0x8000481 StackSize: 0x0 StackMem: 0x80004B1 SP: 0x2004FE54
For more info, visit: https://mbed.com/s/error?error=0x80FF0100&tgt=NUCLEO_F413ZH
-- MbedOS Error Info --
SetSysClock failed
Bootloader mbed_app.json:
"config": {
"update_file": {
"help": "Path to the application update binary on the SD card",
"value": "\"pam_upload_lora.bin\""
"hse_value": {
"value": "8000000",
"macro_name": "HSE_VALUE"
"target_overrides": {
"target.components_add": ["SD"],
"target.clock_source": "USE_PLL_HSE_XTAL|USE_PLL_HSI",
"target.restrict_size":"0x20000"
main application mbed_app.json:
"rtos.main-thread-stack-size": 16384,
"rtos.thread-stack-size": 8192,
"target.bootloader_img": "bootloader_lora.bin",
"target.header_offset": "0x20000",
"target.app_offset": "0x40000"
"config": {
"hse_value": {
"value": "8000000",
header mbed_lib.json:
"name": "application_header",
"target.header_format": [
["magic", "const", "32be", "0x5a51b3d4"],
["headerVersion", "const", "32be", "2"],
["firmwareVersion", "timestamp", "64be", null],
["firmwareSize", "size", "64be", ["application"]],
["firmwareHash", "digest", "SHA256", "application"],
["headerCRC", "digest", "CRCITT32be", "header"]
main.cpp bootloader:
#include "SDBlockDevice.h"
#include "FATFileSystem.h"
#define SD_MOUNT_PATH "sd"
#define FULL_UPDATE_FILE_PATH "/" SD_MOUNT_PATH "/" MBED_CONF_APP_UPDATE_FILE
//#define APPLICATION_ADDR 0x08010400
//#define POST_APPLICATION_ADDR ((APPLICATION_ADDR) + (APPLICATION_SIZE))
#define MY_POST_APPLICATION_ADDR 0x08040000
#if !defined(POST_APPLICATION_ADDR)
#error "target.restrict_size must be set for your target in mbed_app.json"
#endif
# define START_L pinLeft.write(0)
# define STOP_L pinLeft.write(1)
# define START_R pinRight.write(0)
# define STOP_R pinRight.write(1)
//Pin order: MOSI, MISO, SCK, CS
//SDBlockDevice sd(MBED_CONF_APP_SD_CARD_MOSI, MBED_CONF_APP_SD_CARD_MISO,
// MBED_CONF_APP_SD_CARD_SCK, MBED_CONF_APP_SD_CARD_CS);
Serial pc( USBTX, USBRX );
SDBlockDevice sd(D11, D12, D13, D4);
FATFileSystem fs("sd", &sd);
DigitalOut pinLeft(PD_0);
DigitalOut pinRight(PD_1);
FlashIAP flash;
void apply_update(FILE *file, uint32_t address);
// sd.init();
// fs.mount(&sd);
STOP_L;
STOP_R;
FILE *file = fopen(FULL_UPDATE_FILE_PATH, "rb");
if (file != NULL) {
pc.printf("Firmware update found\r\n");
// apply_update(file, POST_APPLICATION_ADDR);
apply_update(file, MY_POST_APPLICATION_ADDR);
fclose(file);
remove(FULL_UPDATE_FILE_PATH);
pc.printf("Update done\r\n");
else
pc.printf("No update found to apply\r\n");
fs.unmount();
pc.printf("SD deinit\r\n");
sd.deinit();
pc.printf("Starting application at addr: %d" "\r\n", MY_POST_APPLICATION_ADDR);
// mbed_start_application(POST_APPLICATION_ADDR);
mbed_start_application(MY_POST_APPLICATION_ADDR);
fseek(file, 0, SEEK_END);
long len = ftell(file);
pc.printf("Firmware size is %ld bytes\r\n", len);
fseek(file, 0, SEEK_SET);
flash.init();
const uint32_t page_size = flash.get_page_size();
char *page_buffer = new char[page_size];
uint32_t addr = address;
uint32_t next_sector = addr + flash.get_sector_size(addr);
bool sector_erased = false;
size_t pages_flashed = 0;
uint32_t percent_done = 0;
while (true) {
// Read data for this page
memset(page_buffer, 0, sizeof(char) * page_size);
int size_read = fread(page_buffer, 1, page_size, file);
if (size_read <= 0) {
break;
// Erase this page if it hasn't been erased
if (!sector_erased) {
if( 0 !=flash.erase(addr, flash.get_sector_size(addr)) )
pc.printf("Erase is NOT OK!\r\n");
sector_erased = true;
// Program page
if( 0 != flash.program(page_buffer, addr, page_size) )
pc.printf("Write is NOT OK!\r\n");
addr += page_size;
if (addr >= next_sector) {
if (++pages_flashed % 3 == 0) {
uint32_t percent_done_new = ftell(file) * 100 / len;
if (percent_done != percent_done_new) {
percent_done = percent_done_new;
pc.printf("Flashed %3ld%%\r", percent_done);
pc.printf("Flashed 100%%\r\n");
delete[] page_buffer;
flash.deinit();
Thx in advance for your help
