KL25Z board,
Moving from Mbed 2 to Mbed-os 6.16.0 using the Keil Cloud compiler.
I get “ARDUINO form factor should not be used any more => use ARDUINO_UNO [-W#warnings]” many many times why?.
normally the “BufferedSerial.h” header cannot be found, why ?
The compiler does not find any problems but the linker finds many they look like this
link Balancer_KL25Z_ADXL213_baremetal.KL25Z
L3912W: Option ‘legacyalign’ is deprecated.
L6218E: Undefined symbol wmemcpy (referred from /opt/ARMCompiler6.15.13/bin/…/lib/libcxx/libcpp_p.l(ios.cpp.o)).
L6218E: Undefined symbol wmemset (referred from /opt/ARMCompiler6.15.13/bin/…/lib/libcxx/libcpp_p.l(ios.cpp.o)).
L6218E: Undefined symbol __ARM_snprintf (referred from /opt/ARMCompiler6.15.13/bin/…/lib/libcxx/libcpp_p.l(locale.cpp.o)).
L6218E: Undefined symbol __ARM_vasprintf (referred from /opt/ARMCompiler6.15.13/bin/…/lib/libcxx/libcpp_p.l(locale.cpp.o)).
L6218E: Undefined symbol __ARM_vsnprintf (referred from /opt/ARMCompiler6.15.13/bin/…/lib/libcxx/libcpp_p.l(locale.cpp.o)).
Because the KL25Z target porintg doesn’t seem to follow latest manner of pin configuration. I recommend you just ignore the warnings. If you don’t want to, you need:
Update target.json from “ARDUINO” to “ARDUINO_UNO” in “supported_form_factors” of the KL25Z
Add proper pin names in PinNames.h
I could not reproduce this problem.
If you use baremetal profile, default C library is small model. To use wchar support functions, you need to use standard mode. So, you can change your mbed_app.json as below:
