Hi
I am trying to read from a bar code scanner with my stm32 NucleoF446RE.
The barcode scanner I am using is GM67 1D 2D Bar Code Scanner .My supply voltage is 5V , using UART 3 . I already have the mbed_app.json file.
the code I followed is BufferedSerial - API references and tutorials | Mbed OS 6 Documentation
#include “mbed.h”
#define MAXIMUM_BUFFER_SIZE 32
static BufferedSerial my_scanner(PC_10, PC_11); // tx, rx
// Application buffer to receive the data
char buf[MAXIMUM_BUFFER_SIZE] = {0};
// Set desired properties (9600-8-N-1).
my_scanner.set_baud(9600);
my_scanner.set_format(8,BufferedSerial::None,1);
printf("Scan an item \n\n");
while(1)
if (uint32_t num = my_scanner.read(buf, sizeof(buf)))
my_scanner.write(buf, num);
printf("%s\n", buf);
I am not getting any readings from the device
