Hi all,
I’ve further investigated and had discussions with the tools team.
The online IDE was primarily designed for pre-6.0 versions of mbed-os. This means that additional steps may be required in order to get some of the 6.x based examples to work.
Please try the following steps:
- Import example
- When the pop up window appears, check the ‘update all libraries to latest versions’ and import
- Once the example has loaded , click on the project name, then select ‘revisions’ from the toolbar
- When the revision list comes up, highlight the version you wish to use (latest being v6.1 branch) and then click ‘switch’ from the toolbar
It should now compile.
Regards
Anna
