C030-R412m: MQTT with CellularContext don't connects
Hi!
I have read some docs and example codes how to connect my target with MQTT. A simple example to make a HTTP request works fine now (like described here: C030-R412m: Cellular device program). But now I want to test a simple MQTT example. What I’m doing wrong? Here what I have done:
Setup
  • Mbed v5.15.6
  • Target C030-R412m
  • Libs
    • mbed-os 5.15.6
    • mbed-mqtt (master)
File mbed_app.json
    "target_overrides": {
            "nsapi.default-cellular-apn": null, // or defined APN
            "nsapi.default-cellular-plmn": null, // or defined PLMN
            "nsapi.default-cellular-sim-pin": null, // no pin configured
            "nsapi.default-cellular-username": null, // not required
            "nsapi.default-cellular-password": null, // not required
            "mbed-trace.enable": true,
            "cellular.debug-at": true,
            "cellular.use-apn-lookup": true,
            "lwip.ethernet-enabled": false
        "UBLOX_C030_R412M": {
            "target.network-default-interface-type": "CELLULAR"
File main.cpp
#include "MQTTClientMbedOs.h"
#include "CellularContext.h"
const char* hostname = "test.mosquitto.org";
uint16_t port = 1883;
SocketAddress addr;
    printf("MQTT test on %s", hostname);
    NetworkInterface *net = CellularContext::get_default_instance();
    net->set_default_parameters();
    while (true) {
        ThisThread::sleep_for(3000);
        if (net && net->get_connection_status() == NSAPI_STATUS_GLOBAL_UP) {
            break;
        } else {
            printf(".");
            fflush(stdout);
The target has attached USB and battery to have enough power.
Output on run
MQTT test on test.mosquitto.org...............................
So, endless tries to connect. Any help is very appreciated! :pensive:
you can check the result (line 113) of net->get_connection_status() method.
But I not see any call of connect(...) method so that is probably the reason why the state of connection will never change.
Hi Jan! Thx. Here a more correct code:
File mbed_app.json
            "cellular.radio-access-technology": 8,
            "lwip.ethernet-enabled": false,
            "lwip.ppp-enabled": true,
            "lwip.tcp-enabled": true,
            "lwip.ipv4-enabled": true,
            "ppp.ipv4-enabled": true,
            "lwip.ipv6-enabled": true,
            "ppp.ipv6-enabled": true
            "GENERIC_AT3GPP.provide-default": true,
            "GENERIC_AT3GPP.tx": "MDMTXD",
            "GENERIC_AT3GPP.rx": "MDMRXD",
File main.cpp
#include "NetworkInterface.h"
#include "cellular_demo_tracing.h"
#define RETRY_COUNT 10
SocketAddress addr;
NetworkInterface *iface;
void print_function(const char *format, ...) {
    trace_mutex.lock();
    va_list arglist;
    va_start( arglist, format );
    vprintf(format, arglist);
    va_end( arglist );
    trace_mutex.unlock();
nsapi_error_t do_connect() {
    nsapi_error_t retcode = NSAPI_ERROR_OK;
    uint8_t retry_counter = 0;
    while (iface->get_connection_status() != NSAPI_STATUS_GLOBAL_UP) {
        retcode = iface->connect();
        if (retcode == NSAPI_ERROR_AUTH_FAILURE) {
            print_function("\n\nAuthentication Failure. Exiting application\n");
        } else if (retcode == NSAPI_ERROR_OK) {
            print_function("\n\nConnection Established.\n");
        } else if (retry_counter > RETRY_COUNT) {
            print_function("\n\nFatal connection failure: %d\n", retcode);
        } else {
            print_function("\n\nCouldn't connect: %d, will retry\n", retcode);
            retry_counter++;
            continue;
        break;
    return retcode;
    trace_open();
    print_function("\n\nMQTT test on %s\n\n", hostname);
    iface = NetworkInterface::get_default_instance();
    MBED_ASSERT(iface);
    iface->set_default_parameters();
    nsapi_error_t retcode = NSAPI_ERROR_NO_CONNECTION;
    if (do_connect() == NSAPI_ERROR_OK) {
        print_function("\n\nConnected\n\n");
    if (iface->disconnect() != NSAPI_ERROR_OK) {
        print_function("\n\n disconnect failed.\n\n");
        print_function("\n\nSuccess. Exiting \n\n");
    } else {
        print_function("\n\nFailure. Exiting \n\n");
    trace_close();
This code output more details for debug. But it says:
[...][ERR ][CELL] Failed to activate network context! (-3004)
  1. Where can I set the URAT (Radio access technology) to 8 for e.g. NBIOT?
  2. Where can I set the MNO Profile?
I do not know about MNO but URAT you already have it
but according to this you probably need number 9 for NB1.
OK, changed to 9. Thx!
Do I need this?
            "target.features_add": ["LWIP"] // <--
Now the targets starts and the output goes to part with AT+CGDCONT? and shows Vodafone APN with type IP but without IP address. After that:
[00024467ms][INFO][CELL]: AT RX (23): .0.0.0",0,0,0,0<cr><ln><cr><ln>OK<cr><ln>
[00024475ms][INFO][CELL]: Found PDP context 1
[00024480ms][INFO][CELL]: CellularContext PPP connect
[00024486ms][INFO][CELL]: AT TX (16): AT+CGDATA="PPP",
[00024492ms][INFO][CELL]: AT TX ( 1): 1
[00024497ms][INFO][CELL]: AT TX ( 1): <cr>
[00024503ms][INFO][CELL]: AT RX ( 5): <cr><ln>ERR
[00024508ms][INFO][CELL]: AT RX ( 4): OR<cr><ln>
[00024514ms][DBG ][CELL]: AT error -3012
[00024518ms][ERR ][CELL]: Failed to CONNECT
[00024523ms][DBG ][CELL]: SYNC do_connect failed with -3012, retry after 16 second
Do it have to do with PSM (power saving mode)? I have read it in this documentation (it has the same chip SARA-R412m) at paragraph Disable PSM and eDRX: Passthrough - SODAQ Support pages
Found this issue on Github: u-blox SARA-R412M with cellular PPP · Issue #10901 · ARMmbed/mbed-os · GitHub
This is strange, because mbed-os-5.15.6 has defined CGDATA to false here: https://github.com/ARMmbed/mbed-os/blob/1faaabb6fad9ce7a3b31553718f8acdb04330b40/features/cellular/framework/targets/UBLOX/AT/UBLOX_AT.cpp#L29
and UBX_MDM_SARA_R41XM is defined here: https://github.com/ARMmbed/mbed-os/blob/1faaabb6fad9ce7a3b31553718f8acdb04330b40/targets/targets.json#L5026
UPDATE
Found out that I need to set UBLOX_AT configs instead of GENERIC_AT3GPP in mbed_app.json.
File mbed_app.json:
            "cellular.clear-on-connect": true,
            "lwip.ppp-enabled": false,
            "ppp.ipv4-enabled": false,
            "ppp.ipv6-enabled": false
            "UBLOX_AT.provide-default": true,
            "UBLOX_AT.tx": "MDMTXD",
            "UBLOX_AT.rx": "MDMRXD",
            "UBLOX_AT.cts": "MDMCTS",
            "UBLOX_AT.rts": "MDMRTS",
File main.cpp:
    trace_mutex.lock();
    va_list arglist;
    va_end( arglist );
        } else {
            retry_counter++;
            continue;
        break;
    return retcode;
    trace_open();
    iface = CellularContext::get_default_instance();
    MBED_ASSERT(iface);
    } else {
    trace_close();
File cellular_demo_tracing.h
 * Copyright (c) 2017 ARM Limited. All rights reserved.
 * Licensed under the Apache License, Version 2.0 (the License); you may
 * not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 * http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an AS IS BASIS, WITHOUT
 * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
#include "Kernel.h"
#include "CellularLog.h"
#include "chrono"
#ifndef CELLULAR_DEMO_TRACING_H_
#define CELLULAR_DEMO_TRACING_H_
#if MBED_CONF_MBED_TRACE_ENABLE
static PlatformMutex trace_mutex;
static void trace_wait()
    trace_mutex.lock();
static void trace_release()
static char* trace_time(size_t ss)
    static char time_st[50];
    snprintf(time_st, 49, "[%08llums]", Kernel::get_ms_count());
    return time_st;
static void trace_open()
    mbed_trace_init();
    mbed_trace_prefix_function_set( &trace_time );
    mbed_trace_mutex_wait_function_set(trace_wait);
    mbed_trace_mutex_release_function_set(trace_release);
    mbed_cellular_trace::mutex_wait_function_set(trace_wait);
    mbed_cellular_trace::mutex_release_function_set(trace_release);
#ifdef MBED_CONF_NSAPI_DEFAULT_CELLULAR_PLMN
    printf("\n\n[MAIN], plmn: %s\n", (MBED_CONF_NSAPI_DEFAULT_CELLULAR_PLMN ? MBED_CONF_NSAPI_DEFAULT_CELLULAR_PLMN : "NULL"));
#endif
static void trace_close()
    mbed_cellular_trace::mutex_wait_function_set(NULL);
    mbed_cellular_trace::mutex_release_function_set(NULL);
    mbed_trace_free();
#else
#endif // #if MBED_CONF_MBED_TRACE_ENABLE
#endif // CELLULAR_DEMO_TRACING_H_
sorry for delay but anyway I am out of ideas for now, sorry.
great
