I am using:
- Mbed Studio 1.3.1
- Mbed OS 5.15
- Windows 10
- Nucelo-F767ZI
I am able to debug the “mbed-os-example-blinky-baremetal-5” example program just fine, but trying to debug my program yields “STLink error (22): DP error”.
What does this error mean and how do I fix it?
Here is my code:
#define NUM_ANALOG_INPUTS 13
#define NUM_DIGITAL_INPUTS 31
#define NUM_DIGITAL_OUTPUTS 3
#define WAIT_TIME 100
static Serial serial(PD_1, PD_0, 115200); // UART4
AnalogIn analogInputs[NUM_ANALOG_INPUTS]
= { AnalogIn(PA_0), AnalogIn(PA_3), AnalogIn(PA_6), AnalogIn(PB_1), AnalogIn(PC_0), AnalogIn(PC_2),
AnalogIn(PC_3), AnalogIn(PC_5), AnalogIn(PF_3), AnalogIn(PF_4), AnalogIn(PF_5), AnalogIn(PF_6), AnalogIn(PF_7) };
DigitalIn digitalInputs[NUM_DIGITAL_INPUTS]
= { DigitalIn(PC_10), DigitalIn(PC_11), DigitalIn(PC_12), DigitalIn(PC_13), DigitalIn(PD_2), DigitalIn(PD_3),
DigitalIn(PD_4), DigitalIn(PD_5), DigitalIn(PD_6), DigitalIn(PD_7), DigitalIn(PE_1), DigitalIn(PE_3), DigitalIn(PB_4),
DigitalIn(PB_5), DigitalIn(PB_6), DigitalIn(PB_8), DigitalIn(PB_9), DigitalIn(PB_10), DigitalIn(PC_7), DigitalIn(PC_9),
DigitalIn(PD_11), DigitalIn(PD_12), DigitalIn(PD_13), DigitalIn(PE_10), DigitalIn(PE_12), DigitalIn(PE_13),
DigitalIn(PE_14), DigitalIn(PE_15), DigitalIn(PF_12), DigitalIn(PF_13), DigitalIn(PG_14) };
DigitalOut digitalOutputs[NUM_DIGITAL_OUTPUTS]
= { DigitalOut(PA_13), DigitalOut(PA_14), DigitalOut(PA_15) };
// This is a bit field for digital inputs. Currently, we need to sample 34 digital inputs
uint32_t digitalInValues = 0;
Timer timer;
serial.printf("\nStart test\n");
// Set pulldowns on digital pins
for(uint8_t i = 0; i < NUM_DIGITAL_INPUTS; i++)
digitalInputs[i].mode(PullDown);
float analogInValues[NUM_ANALOG_INPUTS];
timer.start();
while(true)
for(uint8_t i = 0; i < NUM_ANALOG_INPUTS; i++)
serial.printf("%.3f,", analogInputs[i].read());
for(uint8_t i = 0; i < NUM_DIGITAL_OUTPUTS; i++)
// TODO: Test code. Not sure how we will need to drive these digital outputs
digitalOutputs[i] = 1;
for (uint8_t i = 0; i < NUM_DIGITAL_INPUTS; i++)
int digitalInput = digitalInputs[i];
digitalInValues |= digitalInput << i;
// Print digital inputs, packed into a 32 bit bitfield. Only print the right 31 bits and always print leading zeros.
serial.printf("%u,", digitalInValues);
float timestamp = timer.read();
serial.printf("%.4f\n", timer.read()); // print time from boot in seconds
thread_sleep_for(WAIT_TIME);
The following error log is repeated many times in the debug console. Also, it leaves my system in a state where my CPU usage is high with Python being the culprit.
0018257:ERROR:gdbserver:Unhandled exception in handle_message: STLink error (22): DP error
File "c:\Users\nhopkins\AppData\Local\Mbed Studio\mbed-studio-tools\python\lib\site-packages\pyocd\gdbserver\gdbserver.py", line 381, in handle_message
reply = handler()
File "c:\Users\nhopkins\AppData\Local\Mbed Studio\mbed-studio-tools\python\lib\site-packages\pyocd\gdbserver\gdbserver.py", line 817, in get_registers
return self.create_rsp_packet(self.target_facade.get_register_context())
File "c:\Users\nhopkins\AppData\Local\Mbed Studio\mbed-studio-tools\python\lib\site-packages\pyocd\gdbserver\context_facade.py", line 69, in get_register_context
vals = self._context.read_core_registers_raw(reg_num_list)
File "c:\Users\nhopkins\AppData\Local\Mbed Studio\mbed-studio-tools\python\lib\site-packages\pyocd\debug\cache.py", line 48, in read_core_registers_raw
return self._regcache.read_core_registers_raw(reg_list)
File "c:\Users\nhopkins\AppData\Local\Mbed Studio\mbed-studio-tools\python\lib\site-packages\pyocd\cache\register.py", line 100, in read_core_registers_raw
self._check_cache()
File "c:\Users\nhopkins\AppData\Local\Mbed Studio\mbed-studio-tools\python\lib\site-packages\pyocd\cache\register.py", line 77, in _check_cache
if self._core.is_running():
File "c:\Users\nhopkins\AppData\Local\Mbed Studio\mbed-studio-tools\python\lib\site-packages\pyocd\coresight\cortex_m.py", line 1013, in is_running
return self.get_state() == Target.State.RUNNING
File "c:\Users\nhopkins\AppData\Local\Mbed Studio\mbed-studio-tools\python\lib\site-packages\pyocd\coresight\cortex_m.py", line 982, in get_state
dhcsr = self.read_memory(CortexM.DHCSR)
File "c:\Users\nhopkins\AppData\Local\Mbed Studio\mbed-studio-tools\python\lib\site-packages\pyocd\coresight\cortex_m.py", line 646, in read_memory
result = self.ap.read_memory(addr, transfer_size, now)
File "c:\Users\nhopkins\AppData\Local\Mbed Studio\mbed-studio-tools\python\lib\site-packages\pyocd\probe\stlink_probe.py", line 255, in read_memory
result = conversion.byte_list_to_u32le_list(self._link.read_mem32(addr, 4, self._apsel))[0]
File "c:\Users\nhopkins\AppData\Local\Mbed Studio\mbed-studio-tools\python\lib\site-packages\pyocd\probe\stlink\stlink.py", line 387, in read_mem32
return self._read_mem(addr, size, Commands.JTAG_READMEM_32BIT, self.MAXIMUM_TRANSFER_SIZE, apsel)
File "c:\Users\nhopkins\AppData\Local\Mbed Studio\mbed-studio-tools\python\lib\site-packages\pyocd\probe\stlink\stlink.py", line 347, in _read_mem
raise self._ERROR_CLASSES[status](error_message)
pyocd.core.exceptions.TransferError: STLink error (22): DP error
