Hello all,
I’m currently working with an NRF52840-DK + SX1262MB2xAS LoRa radio shield, plus another DK with a power profiler attached for current measurements. I have things working with my LoRaWAN gateway but struggle to get the power consumption under control.
To investigate the problem I made a simple sketch:
#include <stdio.h>
#include "lorawan/LoRaWANInterface.h"
#include "lorawan/system/lorawan_data_structures.h"
#include "events/EventQueue.h"
// Application helpers
#include "SX126X_LoRaRadio.h"
SX126X_LoRaRadio radio(D11,//MOSI
D12,//MISO
D13,//SCK
D7,//CS/NSS
A0,//RESET
D5,//DIO1
D3,//BUSY
A1,//FREQ_SEL
A2,//DEV_SEL
A3,//XTAL_SEL
D8);//ANT_SW
//DigitalOut led1(LED1);
using namespace events;
uint8_t tx_buffer[30];
uint8_t rx_buffer[30];
#define TX_TIMER 20000
#define MAX_NUMBER_OF_EVENTS 10
#define CONFIRMED_MSG_RETRY_COUNTER 3
#define PC_9 0
static EventQueue ev_queue(MAX_NUMBER_OF_EVENTS *EVENTS_EVENT_SIZE);
static void lora_event_handler(lorawan_event_t event);
static lorawan_app_callbacks_t callbacks;
static LoRaWANInterface lorawan(radio);
//led1 = 0;
// Deep sleep for 1 second
//printf("Deep sleep allowed: %i\r\n", sleep_manager_can_deep_sleep());
while(true) {
ThisThread::sleep_for(1500ms);
Running the above code shows an average current consumption of 6.66mA. Interestingly enough, if you comment out the line before int main() that sets up the radio, the sketch runs with an average current consumption of ~14uA, more or less what I would expect from properly functioning deep sleep.
Any ideas? Worth noting all other config options are default save for my macros in mbed_app.json:
"macros": ["MBEDTLS_USER_CONFIG_FILE=\"mbedtls_lora_config.h\"", "MBED_TICKLESS=1"]
Any and all advice would be much appreciated.
