Dear Sir/Madam
Please advise as to how I can convert the below Arduino code to MBED OS ,
const int RecordTime = 3 ; //Define Measuring Time (Seconds)
const int SensorPin = 3 ; //Define Interrupt Pin (2 or 3 @ Arduino Uno)
int InterruptCounter;
float WindSpeed;
void setup ()
Serial.begin(9600 );
void loop () {
meassure();
Serial.print("Wind Speed: ");
Serial.print(WindSpeed); //Speed in km/h
Serial.print(" km/h - ");
Serial.print(WindSpeed / 3.6 ); //Speed in m/s
Serial.println(" m/s");
void meassure () {
InterruptCounter = 0 ;
attachInterrupt(digitalPinToInterrupt(SensorPin), countup, RISING);
delay(1000 * RecordTime);
detachInterrupt(digitalPinToInterrupt(SensorPin));
WindSpeed = (float )InterruptCounter / (float )RecordTime * 2.4 ;
void countup () {
InterruptCounter++;
HI,
something like this (not tested):
InterruptIn sensor(PA_6); //Change the pin to the pin you will use
int InterruptCounter=0;
float WindSpeed;
void countup () {
InterruptCounter++;
void meassure () {
InterruptCounter=0;
sensor.rise(&countup);
ThisThread::sleep_for(1s); //wait for 1 sec //---> change this to be like delay(1000 * RecordTime);
sensor.rise(NULL);
void loop () {
meassure();
printf("Wind Speed: ");
printf(WindSpeed); //Speed in km/h
printf(" km/h - ");
printf(WindSpeed / 3.6 ); //Speed in m/s
printf(" m/s\n");
int main(){
while(1){
loop();
more examples InterruptIn - API references and tutorials | Mbed OS 6 Documentation
Hello
Please find below the code which modified accordingly but am getting an error on PrintF , please advise on reason for error .
#include “mbed.h”
InterruptIn Anemometer(PB_10);
int Anemometer_Interrupt=0;
float WindSpeed;
void countup () {
Anemometer_Interrupt++;
void meassure () {
Anemometer.rise(&countup);
ThisThread::sleep_for(3s);
Anemometer.rise(NULL);
WindSpeed = (float )Anemometer_Interrupt / (float )RecordTime * 2.4 ;
void loop () {
meassure();
printf("Wind Speed: “);
printf(” km/h - ");
int main(){
while(1){
loop();
Thanks
HI,
This should compile … I tested to compile.
float WindSpeed;
void countup ()
void meassure ()
void loop ()
meassure();
printf("%f",WindSpeed); //Speed in km/h
printf(" km/h - ");
while(1) {
loop();
JohnnyK
(Jan Kamidra)
5
for printing floats you need to change settings in mbed_app.json
"target_overrides": {
"target.printf_lib": "std"
- The variable
Anemometer_Interrupt have to be cleared to zero at the start of the measure function for next iteration.
- the variable
Anemometer_Interrupt should be volatile
Hello
Thanks it did just have an issue with serial output result as per below showing %f ?
Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f km/h - Wind Speed: %f
Thanks for the assistance
