I am working with an STM32L4S7ZIT6 MCU. The MCU is on a NUCLEO-L4A6ZG board. I have to prepare a bootloader for this MCU. So I started doing some very primitive tests starting from the blinky example. Here is my main.cpp:
#include <mbed.h>
#include "serial_wire.hpp"
#include "PinNames.h"
#define BLINKING_RATE 500ms
#ifdef BOOTLOADER
DigitalOut led(LED1);
#else
DigitalOut led(LED2);
#endif
Thread blink_thread(osPriorityNormal, OS_STACK_SIZE, nullptr, "blinky-klinky");
FileHandle *mbed::mbed_override_console(int) {
static SWO_Channel debugport("swo_channel");
return &debugport;
void blinky(void) {
debug("blinky starts...\n");
while(true) {
led.write(0);
led.write(1);
debug("run blinky run\n");
debug("fw starts here\n");
// ThisThread::sleep_for(1ms); <- Here is the problem
blink_thread.start(blinky);
ThisThread::sleep_for(2000ms);
#ifdef BOOTLOADER
debug("switching to the application at: 0x%x\n", POST_APPLICATION_ADDR);
mbed_start_application(POST_APPLICATION_ADDR);
#endif
debug("app starts here\n");
while (true) {
debug("#GRN#infinite loop\r\n");
It is very clear, simple and straight forward. My only purpose was being sure that I am jumping from the btl. to the app. However, I discovered that the MCU is hanging once it starts the thread when I comment out the 1ms delay. I must uncomment the delay to get it work. Or I have to remove the debug() functions either in the thread or at the beginning of main(). What I do not understand is this does not happen when I run the same code on an F407VGT MCU. Why I observe this issue? It is very annoying because I observe the same behaviour also in the release fw. Here someone had the same issue when he calls printf() in an ISR. One of the answers says: printf() is not normally reentrant. I believe I am having the same problem with him but I still do not have an answer why the same code runs on an F407VGT without any issue? Does anybody have an idea?
Quick notes: F407 works @ 168 mhz while L4S7 @ 120. At the very beginning I was building the code without bootloader functionality (without any shifting in the text section). But it was always the same from the beginning
Thanks
