There is no function that can tell you the status of the SDBlockDevice. (_is_initialized) variable is private and no function return the value.
This peace of code will be executed more than one times … when the SD device fails to read/access from the SD disk.
FILE : SDBlockDevice.c – >line 386
int SDBlockDevice::init()
int err;
lock();
if (!_is_initialized) {
_init_ref_count = 0;
_init_ref_count++; <<<<<<<<<<<<<<<<<<<<<<<<<This line is wrong
if (_init_ref_count != 1) { <<<<<<<<<<<<<<<<<<<<<<<<<This line is wrong
goto end;
The _init_ref_count variable will be continuously each time … when there is a problem. SDBLOCKDEVICE doesn’t demount when it fails to access the SD disk … but it will increment that variable contentiously.
There is no way to know if the SD disk is not reachable to re-initialize and remount since it is initialized already but fails even so to access the SD disk. By knowing what value the _init_ref_count has you can deinitialize it so many times and initialize it again and everything works again.
To regenerate this error:
Define your SDBLOCK device, access the file system (read or make DIR) … Take out the SD card physically and make another SD-Disk operation … It will fails sure …
Put back the SD-Disk … And you get the problem. . The SDBlockdevice will fail until you deinitialize so many times as _init_ref_count incremented before.
I don’t know what is the usage of _init_ref_count, but it is wrong .
Why dose SDblockdevice re-call SDBlockDevice::init() again and again while you didn’t do that?
must be a bug … or I don’t know hot to fix the fact that when the SD-Disk physically removed and accessed to re-initialize it in a proper way.
I hope it is clear what I am talking about.
