DTLS 1.2 using MBEDTLS; error during HANDSHAKE
I am using MBedTLS library on my STM32 device to run a DTLS 1.2 Client. I am then communicating over a serial interface with a DTLS 1.2 Server running on Windows 11 using the openssl library. A python script is use to tunnel the message from the serial port to the UDP port of the server.
Additional info:
  • I am using PSK and no certificates.
  • The openssl server and openssl client running on a localhost are able to create a session successfully.
  • openssl version is 3.4.1
I receive an error during the handshake process. The server is unable to generate a new session ticket and tries instead to send “Server Hello” and “Server Hello Done”. Is there anything that I need to take into consideration while implementing the DTLS 1.2 client to avoid this behavior.
The communication seems to end this way,
BR
I met the same issue, but not in DTLS (I have other issues in DTLS handshaking). It’s failed in the last step of the TLS 1.2, decrypting the “client_finished“ message by using the generated key.
You can print out the log to see if the same issue reported. I doubt the mbedTLS is not compliant with OpenSSL somewhere when using the PSK-AES ciphersuites.
Here is part the failure point of my logs:
mbedtls_cipher_auth_decrypt_ext() returned -25344 (-0x6300)
ssl_decrypt_buf() returned -29056 (-0x7180)
=> send alert message
send alert level=2 message=20
If you found any solution, feel free to let us know here!
J.W
