I want to be able to dynamically change 2 pins from Serial (RX and TX) to one DigitalIn and One InterruptIn.
I can dynamically assign the pins at startup, but I cannot change it after that. Is there a way to do that. Here is my code now.
#define MODE_SERIAL 0
#define MODE_STEP_DIR 1
#define UART_TX PA_2
#define UART_RX PA_3
int mode = MODE_SERIAL;
Serial *pc;
InterruptIn *step;
DigitalIn *dir;
void set_mode(int new_mode) {
delete step;
delete dir;
delete pc;
if (new_mode == MODE_SERIAL) {
pc = new Serial(UART_TX, UART_RX);
pc->baud(921600);
pc->attach(&serial_interrupt);
else {
step = new InterruptIn(UART_RX);
step->rise(&stepInt);
dir = new DigitalIn(UART_TX);
mode = new_mode;
This is called once in main(), which works, then subsequent calls don’t work.
Note: The deletes at the beginning were an experiment and had no effect.
