I have a raw binary x and y points on a prime256v1 curve. I want to convert this to some mbedtls structure, and then to a mbedtls_pk_context that I can write to PEM.
Is there an equivalent to mbedtls_rsa_import_raw? Or sample code?
The higher level task is that I need a complete set of converters between raw binary, mbedtls structures, DER, and PEM for both ECC and RSA.
A pointer to sample code, a tutorial, book, or wiki would be welcome.
For the record, in case it helps someone else, my flow is:
mbedtls_pk_init
mbedtls_pk_info_from_type(MBEDTLS_PK_ECKEY);
mbedtls_pk_setup
mbedtls_pk_ec
mbedtls_ecp_group_init
mbedtls_ecp_group_load(grp, MBEDTLS_ECP_DP_SECP256R1);
get the mbedtls_ecp_point Q
mbedtls_ecp_point_init
get the Q members X Y Z
for X Y
mbedtls_mpi_read_binary (the raw binary X Y)
for Z = 1
mbedtls_pk_write_pubkey_pem
and then write the buffer
