I’m trying to connect to iot.eclipse.org in TLS. I have already successfully connected to test.mosquitto.org using TLS.
Unfortunately, even if I took the server certificate using the command “openssl s_client -showcerts -connect iot.eclipse.org:8883” and put them into my firmware, I can’t connect to this broker.
Here attached the log:
=> handshake
, at line 6557 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
client state: 0
, at line 3363 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
=> flush output
, at line 2416 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
<= flush output
, at line 2428 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
client state: 1
=> flush output
<= flush output
=> write client hello
, at line 719 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
client hello, max version: [3:3]
, at line 757 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
client hello, current time: 0
, at line 695 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
dumping 'client hello, random bytes' (32 bytes)
, at line 766 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
0000: 00 00 00 00 3c 3e 67 c0 9f da f3 11 7c 21 27 44 ....<>g.....|!'D
0010: 6c 98 e2 d6 87 6c 65 27 40 0c 0b ce 13 e8 43 ca l....le'@.....C.
client hello, session id len.: 0
, at line 819 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
dumping 'client hello, session id' (0 bytes)
, at line 820 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
client hello, add ciphersuite: c02c
, at line 887 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
client hello, add ciphersuite: c02b
client hello, add ciphersuite: c030
client hello, got 4 ciphersuites
, at line 920 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
client hello, compress len.: 1
, at line 951 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
client hello, compress alg.: 0
, at line 953 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
client hello, adding signature_algorithms extension
, at line 178 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
client hello, adding supported_elliptic_curves extension
, at line 263 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
client hello, adding supported_point_formats extension
, at line 328 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
client hello, total extension length: 38
, at line 1025 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
=> write record
, at line 2701 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
output record: msgtype = 22, version = [3:1], msglen = 91
, at line 2838 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
=> flush output
message length: 96, out_left: 96
, at line 2435 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
ssl->f_send() returned 96 (-0xffffffa0)
, at line 2441 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
<= flush output
, at line 2460 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
<= write record
, at line 2850 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
<= write client hello
, at line 1051 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
client state: 2
=> flush output
<= flush output
=> parse server hello
, at line 1447 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
=> read record
, at line 3721 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
=> fetch input
, at line 2208 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
in_left: 0, nb_want: 5
, at line 2366 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
, at line 2390 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
ssl->f_recv(_timeout)() returned 0 (-0x0000)
, at line 2391 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
mbedtls_ssl_fetch_input() returned -29312 (-0x7280)
, at line 3875 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
mbedtls_ssl_read_record_layer() returned -29312 (-0x7280)
, at line 3729 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
mbedtls_ssl_read_record() returned -29312 (-0x7280)
, at line 1454 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
<= handshake
, at line 6567 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
=> handshake
client state: 2
=> flush output
<= flush output
=> read record
=> fetch input
<= handshake
=> handshake
client state: 2
=> flush output
<= flush output
=> read record
=> fetch input
ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
<= fetch input
, at line 2403 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
input record: msgtype = 22, version = [3:3], msglen = 89
, at line 3487 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
=> fetch input
in_left: 5, nb_want: 94
ssl->f_recv(_timeout)() returned 89 (-0xffffffa7)
<= fetch input
handshake message: msglen = 89, type = 2, hslen = 89
, at line 3089 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
<= read record
, at line 3754 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
dumping 'server hello, version' (2 bytes)
, at line 1527 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
0000: 03 03 ..
server hello, current time: 1545132704
, at line 1553 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
dumping 'server hello, random bytes' (32 bytes)
, at line 1560 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
0000: 5c 18 da a0 5a 34 fd 82 d5 2b 2b 15 01 54 f9 d7 \...Z4...++..T..
0010: 66 2d 76 08 80 14 86 08 17 33 0e 2c 89 d6 85 28 f-v......3.,...(
server hello, session id len.: 32
, at line 1640 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
dumping 'server hello, session id' (32 bytes)
, at line 1641 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
0000: fe 8a e7 04 29 a4 3b 99 14 b5 c4 f9 68 3b 62 83 ....).;.....h;b.
0010: 31 35 d3 dd 9d 34 4c 84 7e 6c 76 95 f5 ab 61 f7 15...4L.~lv...a.
no session has been resumed
, at line 1679 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
server hello, chosen ciphersuite: c030
, at line 1681 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
server hello, compress alg.: 0
, at line 1682 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
server hello, chosen ciphersuite: TLS-ECDHE-RSA-WITH-AES-256-GCM-SHA384
, at line 1698 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
server hello, total extension length: 13
, at line 1733 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
found renegotiation extension
, at line 1753 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
found supported_point_formats extension
, at line 1832 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
<= parse server hello
, at line 1922 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_cli.c
client state: 3
=> flush output
<= flush output
=> parse certificate
, at line 4320 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
=> read record
=> fetch input
<= fetch input
input record: msgtype = 22, version = [3:3], msglen = 2737
=> fetch input
in_left: 5, nb_want: 2742
, at line 3917 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
, at line 4360 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
<= handshake
=> handshake
client state: 3
=> flush output
<= flush output
=> read record
=> fetch input
in_left: 5, nb_want: 5
<= fetch input
=> fetch input
<= handshake
mbedtls_ssl_handshake() returned -29312 (-0x7280)
, at line 7160 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
=> free
, at line 7344 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
<= free
, at line 7409 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
=> handshake
client state: 0
=> flush output
<= flush output
client state: 1
=> flush output
<= flush output
=> write record
=> flush output
<= flush output
<= write record
client state: 2
=> flush output
<= flush output
=> read record
=> fetch input
<= fetch input
input record: msgtype = 11, version = [0:10], msglen = 44288
unknown record type
, at line 3495 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
=> send alert message
, at line 4124 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
send alert level=2 message=10
, at line 4125 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
=> write record
output record: msgtype = 21, version = [3:1], msglen = 2
=> flush output
message length: 7, out_left: 7
ssl->f_send() returned 7 (-0xfffffff9)
<= flush output
<= write record
<= send alert message
, at line 4137 in file ..\Middlewares\Third_Party\mbedTLS\library\ssl_tls.c
mbedtls_ssl_read_record_layer() returned -29184 (-0x7200)
mbedtls_ssl_read_record() returned -29184 (-0x7200)
<= handshake
=> handshake
client state: 2
=> flush output
<= flush output
=> read record
=> fetch input
<= fetch input
unknown record type
=> write record
=> flush output
<= flush output
<= write record
<= handshake
=> handshake
client state: 2
=> flush output
<= flush output
=> read record
=> fetch input
<= fetch input
unknown record type
=> write record
=> flush output
<= flush output
<= write record
<= handshake
mqtt_connection_cb: Disconnected, reason: 256
What could be the reason?
Thank you,
Mattia Berton
