Hello guys ,
I Hope that any one can help me in the following
I used event queue as a timer instead of RTOS Timer to read a value from sensor and printf it
The problem is that I want to make that infinty times but with eventqueue get out of memory very early how can I solve this problem given that I enlrage the stacke of event in (mbed-os/events/mbed_lib.json). code :
EventQueue queue_temperatureTimer;
int temperatureTimer_id;
void startTimer(){
temperatureTimer_id = queue_temperatureTimer.call_every(5000, &temperatureTimerExpired);
printf("temperatureTimer_id :%i\n",temperatureTimer_id);
if(temperatureTimer_id ==0 )
printf("not enough memory to allocate the event\n");
else{
printf("Timer started");
queue_temperatureTimer.dispatch();
void temperatureTimerExpired() {
t_uint32 temperatureValue
int cancelReturn;
/read value of Temperature Sensor /
printf("temperatureTimerExpired()\n");
queue_temperatureTimer.cancel(temperatureTimer_id);
printf("cancelReturn %i\n",cancelReturn);
temperatureValue= sal_getTemperatureValue();
printf(" temperatureValue : %lu \n ",temperatureValue);
/restart the timer with Normal Value /
startTimer();
startTimer();
hudakz
(Zoltan Hudak)
May 29, 2020, 7:35am
2
Hello Esraa,
You can try the following:
In the startTimer function replace
with
queue_temperatureTimer.dispatch_forever();
Then replace the temperatureTimerExpired function with the following one:
t_uint32 temperatureValue;
temperatureValue = sal_getTemperatureValue();
printf(" temperatureValue : %lu \n ", temperatureValue);
Best regards,
Zoltan
hudakz:
Thanks alot , this solution works with me …
esraahatem:
ispatch();
I have another question is I want to restart the timer (the same timer )with different values each time the timer expired and in this time the same problem of stack overflow happened
so have you why that happens
and thanks a lot again for your help
hudakz
(Zoltan Hudak)
June 1, 2020, 6:28pm
5
Hello Esraa,
Try the following and observe LED1:
DigitalOut led1(LED1);
EventQueue eventQueue;
Thread thread;
bool call_in_Enabled = true;
int timeout = 50; // initial timeout in ms
void onTimeout()
led1 = !led1;
timeout += 10; // change timeout
if (timeout > 500) {
timeout = 50; // reset
call_in_Enabled = true; //enable call_in
thread.start(callback(&eventQueue, &EventQueue::dispatch_forever));
while (true) {
if (call_in_Enabled) {
call_in_Enabled = false; // disable call_in
eventQueue.call_in(timeout, onTimeout);
Best regards,
Zoltan
hudakz:
call_in_Enabled
Really Thanks a lot for all the support you provided to me , that helped me a lot .As I’m new in mbed os
