Hey there!
I’m trying to connect the Microchip KSZ8081MLX to an STM32F207ZG using the MII interface. However, I am still getting an error -3004 (not connected to a network ).
I have already made a custom mbed_app.json:
"target_overrides": {
"stm32-emac.eth-phy-address": 1,
"stm32-emac.eth-phy-media-interface": "ETH_MEDIA_INTERFACE_MII",
"stm32-emac.eth-phy-DuplexMode": "ETH_MODE_HALFDUPLEX",
"stm32-emac.eth-phy-Speed": "ETH_SPEED_10M"
But unfortunately this did not solve my problem. Now I noticed there are no MII pins declared for the F207ZG in PerihperalPins.c, only RMII pins. I was wondering how I should go about changing this.
Any other tips/tricks would be welcome! Thanks in advance
Edit #1: Actually I don’t see them declared anywhere, I just would like to double-check the pin-out.
Edit #2: I re-soldered the chip, now there is a connection but I am getting error -3010 (DHCP failure). The device is connected to a switch, which is connected to a router with DHCP enabled…
Edit #3: Added the following:
"stm32-emac.eth-phy-Speed": "ETH_SPEED_10M",
"stm32-emac.eth-phy-status-register": "30",
"stm32-emac.eth-phy-speed-status": "0x0001",
"stm32-emac.eth-phy-duplex-status": "0x0004"
Still no luck.
Edit #4: added contents from STM32CubeMX pinout export from “STM32CubeProject/Src/stm32f2xx_hal_msp.c” to my MedOS project “MbedOsProject/mbed-os/features/netsocket/emac-drivers/TARGET_STM/TARGET_STM32f2/TARGET_NUCLEO_F207ZG/stm32f2_eth_init.c”. The system is now working correctly. I will post the contents of “stm32f2_eth_init.c”, maybe it will help someone:
#ifndef USE_USER_DEFINED_HAL_ETH_MSPINIT
#include "stm32f2xx_hal.h"
* Override HAL Eth Init function
void HAL_ETH_MspInit(ETH_HandleTypeDef* heth)
GPIO_InitTypeDef GPIO_InitStruct = {0};
if(heth->Instance==ETH)
/* Peripheral clock enable */
__HAL_RCC_ETH_CLK_ENABLE();
__HAL_RCC_GPIOE_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
/**ETH GPIO Configuration
PE2 ------> ETH_TXD3
PC1 ------> ETH_MDC
PC2 ------> ETH_TXD2
PC3 ------> ETH_TX_CLK
PA0-WKUP ------> ETH_CRS
PA1 ------> ETH_RX_CLK
PA2 ------> ETH_MDIO
PA3 ------> ETH_COL
PA7 ------> ETH_RX_DV
PC4 ------> ETH_RXD0
PC5 ------> ETH_RXD1
PB0 ------> ETH_RXD2
PB1 ------> ETH_RXD3
PB10 ------> ETH_RX_ER
PB11 ------> ETH_TX_EN
PB12 ------> ETH_TXD0
PB13 ------> ETH_TXD1
GPIO_InitStruct.Pin = GPIO_PIN_2;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF11_ETH;
HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4
|GPIO_PIN_5;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
|GPIO_PIN_7;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_10|GPIO_PIN_11
|GPIO_PIN_12|GPIO_PIN_13;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
/* Enable the Ethernet global Interrupt */
HAL_NVIC_SetPriority(ETH_IRQn, 0x7, 0);
HAL_NVIC_EnableIRQ(ETH_IRQn);
/* Enable ETHERNET clock */
* Override HAL Eth DeInit function
void HAL_ETH_MspDeInit(ETH_HandleTypeDef *heth)
/* USER CODE BEGIN ETH_MspDeInit 0 */
/* USER CODE END ETH_MspDeInit 0 */
/* Peripheral clock disable */
__HAL_RCC_ETH_CLK_DISABLE();
PC1 ------> ETH_MDC
PA3 ------> ETH_COL
HAL_GPIO_DeInit(GPIOE, GPIO_PIN_2);
HAL_GPIO_DeInit(GPIOC, GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4
|GPIO_PIN_5);
HAL_GPIO_DeInit(GPIOA, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
|GPIO_PIN_7);
HAL_GPIO_DeInit(GPIOB, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_10|GPIO_PIN_11
|GPIO_PIN_12|GPIO_PIN_13);
/* ETH interrupt DeInit */
HAL_NVIC_DisableIRQ(ETH_IRQn);
#endif /* USE_USER_DEFINED_HAL_ETH_MSPINIT */
I saw a post mention being able to override these files using a custom build target, any pointers?
