I got a project using MQTT with SSL mutual auth. with ECDSA key type and SHA-256.
I got a -0x50 error, find the debug logs below :
(7236) mbedtls: mbedtls\library\ssl_tls.c:8086
=> handshake(7240) mbedtls: mbedtls\library\ssl_cli.c:3510
client state: 0(7254) mbedtls: mbedtls\library\ssl_tls.c:2755
=> flush output(7268) mbedtls: mbedtls\library\ssl_tls.c:2767
<= flush output(7282) mbedtls: mbedtls\library\ssl_cli.c:3510
client state: 1(7297) mbedtls: mbedtls\library\ssl_tls.c:2755
=> flush output(7311) mbedtls: mbedtls\library\ssl_tls.c:2767
<= flush output(7325) mbedtls: mbedtls\library\ssl_cli.c:774 => write client hello
(7345) mbedtls: mbedtls\library\ssl_tls.c:3184
=> write handshake message(7357) mbedtls: mbedtls\library\ssl_tls.c:3343
=> write record(7374) mbedtls: mbedtls\library\ssl_tls.c:2755
=> flush output(7383) mbedtls: mbedtls\library\ssl_tls.c:2774
message length: 220, out_left: 220(7402) mbedtls: mbedtls\library\ssl_tls.c:2779
ssl->f_send() returned 220 (-0xffffff24)(7416) mbedtls: mbedtls\library\ssl_tls.c:2807
<= flush output(7430) mbedtls: mbedtls\library\ssl_tls.c:3476
<= write record(7444) mbedtls: mbedtls\library\ssl_tls.c:3320
<= write handshake message(7459) mbedtls: mbedtls\library\ssl_cli.c:1106
<= write client hello(7474) mbedtls: mbedtls\library\ssl_cli.c:3510
client state: 2(7488) mbedtls: mbedtls\library\ssl_tls.c:2755
=> flush output(7503) mbedtls: mbedtls\library\ssl_tls.c:2767
<= flush output(7517) mbedtls: mbedtls\library\ssl_cli.c:1499
=> parse server hello(7532) mbedtls: mbedtls\library\ssl_tls.c:4311
=> read record(7546) mbedtls: mbedtls\library\ssl_tls.c:2536
=> fetch input(7560) mbedtls: mbedtls\library\ssl_tls.c:2697
in_left: 0, nb_want: 5(7575) mbedtls: mbedtls\library\ssl_tls.c:2721
in_left: 0, nb_want: 5(7590) mbedtls: mbedtls\library\ssl_tls.c:2722
ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)(7607) mbedtls: mbedtls\library\ssl_tls.c:2742
<= fetch input(7622) mbedtls: mbedtls\library\ssl_tls.c:2536
=> fetch input(7635) mbedtls: mbedtls\library\ssl_tls.c:2697
in_left: 5, nb_want: 92(7650) mbedtls: mbedtls\library\ssl_tls.c:2721
in_left: 5, nb_want: 92(7665) mbedtls: mbedtls\library\ssl_tls.c:2722
ssl->f_recv(_timeout)() returned 87 (-0xffffffa9)(7682) mbedtls: mbedtls\library\ssl_tls.c:2742
<= fetch input(7701) mbedtls: mbedtls\library\ssl_tls.c:4385
<= read record(7713) mbedtls: mbedtls\library\ssl_cli.c:1789
server hello, total extension length: 11(7727) mbedtls: mbedtls\library\ssl_cli.c:1978
<= parse server hello(7741) mbedtls: mbedtls\library\ssl_cli.c:3510
client state: 3(7756) mbedtls: mbedtls\library\ssl_tls.c:2755
=> flush output(7770) mbedtls: mbedtls\library\ssl_tls.c:2767
<= flush output(7784) mbedtls: mbedtls\library\ssl_tls.c:5655
=> parse certificate(7799) mbedtls: mbedtls\library\ssl_tls.c:4311
=> read record(7813) mbedtls: mbedtls\library\ssl_tls.c:2536
=> fetch input(7827) mbedtls: mbedtls\library\ssl_tls.c:2697
in_left: 0, nb_want: 5(7842) mbedtls: mbedtls\library\ssl_tls.c:2721
in_left: 0, nb_want: 5(7857) mbedtls: mbedtls\library\ssl_tls.c:2722
ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)(7874) mbedtls: mbedtls\library\ssl_tls.c:2742
<= fetch input(7888) mbedtls: mbedtls\library\ssl_tls.c:2536
=> fetch input(7902) mbedtls: mbedtls\library\ssl_tls.c:2697
in_left: 5, nb_want: 993(7917) mbedtls: mbedtls\library\ssl_tls.c:2721
in_left: 5, nb_want: 993(7932) mbedtls: mbedtls\library\ssl_tls.c:2722
ssl->f_recv(_timeout)() returned 988 (-0xfffffc24)(7950) mbedtls: mbedtls\library\ssl_tls.c:2742
<= fetch input(7983) mbedtls: mbedtls\library\ssl_tls.c:4385
<= read record(9854) mbedtls: mbedtls\library\ssl_tls.c:5863
<= parse certificate(9858) mbedtls: mbedtls\library\ssl_cli.c:3510
client state: 4(9872) mbedtls: mbedtls\library\ssl_tls.c:2755
=> flush output(9887) mbedtls: mbedtls\library\ssl_tls.c:2767
<= flush output(9901) mbedtls: mbedtls\library\ssl_cli.c:2336
=> parse server key exchange(9916) mbedtls: mbedtls\library\ssl_tls.c:4311
=> read record(9930) mbedtls: mbedtls\library\ssl_tls.c:2536
=> fetch input(9945) mbedtls: mbedtls\library\ssl_tls.c:2697
in_left: 0, nb_want: 5(9960) mbedtls: mbedtls\library\ssl_tls.c:2721
in_left: 0, nb_want: 5(9974) mbedtls: mbedtls\library\ssl_tls.c:2722
ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)(9991) mbedtls: mbedtls\library\ssl_tls.c:2742
<= fetch input(10006) mbedtls: mbedtls\library\ssl_tls.c:2536 => fetch input
(10020) mbedtls: mbedtls\library\ssl_tls.c:2697 in_left: 5, nb_want: 220
(10035) mbedtls: mbedtls\library\ssl_tls.c:2721 in_left: 5, nb_want: 220
(10050) mbedtls: mbedtls\library\ssl_tls.c:2722 ssl->f_recv(_timeout)() returned 215 (-0xffffff29)
(10067) mbedtls: mbedtls\library\ssl_tls.c:2742 <= fetch input
(10086) mbedtls: mbedtls\library\ssl_tls.c:4385 <= read record
(10100) mbedtls: mbedtls\library\ssl_cli.c:2044 ECDH curve: secp521r1
(10113) mbedtls: mbedtls\library\ssl_cli.c:2278 Server used SignatureAlgorithm 3
(10126) mbedtls: mbedtls\library\ssl_cli.c:2279 Server used HashAlgorithm 6
(11980) mbedtls: mbedtls\library\ssl_cli.c:2664 <= parse server key exchange
(11985) mbedtls: mbedtls\library\ssl_cli.c:3510 client state: 5
(11999) mbedtls: mbedtls\library\ssl_tls.c:2755 => flush output
(12013) mbedtls: mbedtls\library\ssl_tls.c:2767 <= flush output
(12028) mbedtls: mbedtls\library\ssl_cli.c:2697 => parse certificate request
(12043) mbedtls: mbedtls\library\ssl_tls.c:4311 => read record
(12058) mbedtls: mbedtls\library\ssl_tls.c:2536 => fetch input
(12072) mbedtls: mbedtls\library\ssl_tls.c:2697 in_left: 0, nb_want: 5
(12087) mbedtls: mbedtls\library\ssl_tls.c:2721 in_left: 0, nb_want: 5
(12102) mbedtls: mbedtls\library\ssl_tls.c:2722 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
(12119) mbedtls: mbedtls\library\ssl_tls.c:2742 <= fetch input
(12134) mbedtls: mbedtls\library\ssl_tls.c:2536 => fetch input
(12147) mbedtls: mbedtls\library\ssl_tls.c:2697 in_left: 5, nb_want: 291
(12164) mbedtls: mbedtls\library\ssl_tls.c:2721 in_left: 5, nb_want: 291
(12178) mbedtls: mbedtls\library\ssl_tls.c:2722 ssl->f_recv(_timeout)() returned 286 (-0xfffffee2)
(12195) mbedtls: mbedtls\library\ssl_tls.c:2742 <= fetch input
(12215) mbedtls: mbedtls\library\ssl_tls.c:4385 <= read record
(12224) mbedtls: mbedtls\library\ssl_cli.c:2846 <= parse certificate request
(12239) mbedtls: mbedtls\library\ssl_cli.c:3510 client state: 6
(12253) mbedtls: mbedtls\library\ssl_tls.c:2755 => flush output
(12267) mbedtls: mbedtls\library\ssl_tls.c:2767 <= flush output
(12282) mbedtls: mbedtls\library\ssl_cli.c:2856 => parse server hello done
(12297) mbedtls: mbedtls\library\ssl_tls.c:4311 => read record
(12311) mbedtls: mbedtls\library\ssl_tls.c:2536 => fetch input
(12325) mbedtls: mbedtls\library\ssl_tls.c:2697 in_left: 0, nb_want: 5
(12342) mbedtls: mbedtls\library\ssl_tls.c:2721 in_left: 0, nb_want: 5
(12356) mbedtls: mbedtls\library\ssl_tls.c:2722 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
(12373) mbedtls: mbedtls\library\ssl_tls.c:2742 <= fetch input
(12387) mbedtls: mbedtls\library\ssl_tls.c:2536 => fetch input
(12401) mbedtls: mbedtls\library\ssl_tls.c:2697 in_left: 5, nb_want: 9
(12416) mbedtls: mbedtls\library\ssl_tls.c:2721 in_left: 5, nb_want: 9
(12431) mbedtls: mbedtls\library\ssl_tls.c:2722 ssl->f_recv(_timeout)() returned 4 (-0xfffffffc)
(12448) mbedtls: mbedtls\library\ssl_tls.c:2742 <= fetch input
(12463) mbedtls: mbedtls\library\ssl_tls.c:4385 <= read record
(12477) mbedtls: mbedtls\library\ssl_cli.c:2886 <= parse server hello done
(12492) mbedtls: mbedtls\library\ssl_cli.c:3510 client state: 7
(12506) mbedtls: mbedtls\library\ssl_tls.c:2755 => flush output
(12520) mbedtls: mbedtls\library\ssl_tls.c:2767 <= flush output
(12535) mbedtls: mbedtls\library\ssl_tls.c:5329 => write certificate
(12553) mbedtls: mbedtls\library\ssl_tls.c:3184 => write handshake message
(12566) mbedtls: mbedtls\library\ssl_tls.c:3343 => write record
(12588) mbedtls: mbedtls\library\ssl_tls.c:2755 => flush output
(12593) mbedtls: mbedtls\library\ssl_tls.c:2774 message length: 500, out_left: 500
(12611) mbedtls: mbedtls\library\ssl_tls.c:2779 ssl->f_send() returned 500 (-0xfffffe0c)
(12626) mbedtls: mbedtls\library\ssl_tls.c:2807 <= flush output
(12640) mbedtls: mbedtls\library\ssl_tls.c:3476 <= write record
(12655) mbedtls: mbedtls\library\ssl_tls.c:3320 <= write handshake message
(12670) mbedtls: mbedtls\library\ssl_tls.c:5433 <= write certificate
(12685) mbedtls: mbedtls\library\ssl_cli.c:3510 client state: 8
(12699) mbedtls: mbedtls\library\ssl_tls.c:2755 => flush output
(12713) mbedtls: mbedtls\library\ssl_tls.c:2767 <= flush output
(12728) mbedtls: mbedtls\library\ssl_cli.c:2898 => write client key exchange
(16283) mbedtls: mbedtls\library\ssl_tls.c:3184 => write handshake message
(16289) mbedtls: mbedtls\library\ssl_tls.c:3343 => write record
(16305) mbedtls: mbedtls\library\ssl_tls.c:2755 => flush output
(16317) mbedtls: mbedtls\library\ssl_tls.c:2774 message length: 143, out_left: 143
(16333) mbedtls: mbedtls\library\ssl_tls.c:2779 ssl->f_send() returned -80 (-0x0050)
(16349) mbedtls: mbedtls\library\ssl_tls.c:3472 mbedtls_ssl_flush_output() returned -80 (-0x0050)
(16366) mbedtls: mbedtls\library\ssl_tls.c:3315 ssl_write_record() returned -80 (-0x0050)
(16383) mbedtls: mbedtls\library\ssl_cli.c:3168 mbedtls_ssl_write_handshake_msg() returned -80 (-0x0050)
(16400) mbedtls: mbedtls\library\ssl_tls.c:8096 <= handshake
(16414) esp-tls: mbedtls_ssl_handshake returned -0x50
(16420) esp-tls: Certificate verified.
(16429) esp-tls: Failed to open new connection
(16430) TRANS_SSL: Failed to open a new connection
(16436) MQTT_CLIENT: Error transport connect
As broker we use VerneMQ ( https://docs.vernemq.com/configuration/logging ), even in debug mode there are no interesting logs to help.
We are connecting with mosquitto in this following way :
mosquitto_sub -h <dns> -p <port> --cafile CA.crt -t "<topic>" -q 0 -i <clientid> -P <password> -u <username> -d --cert Middle/devices/PRIME256/cert.crt --key Middle/devices/PRIME256/key.pem --insecure
–insecure is used because the broker cert CN is not the actual broker DNS, so we had to add this code :
We instantly return before check CN to avoid problems.
Can this cause unwanted side effects ?
I tried with a broker certificate where CN is OK and without the return but I got the same error on f_rcv(_timeout).
I also tried to connect with openssl with a correct CN and I got no problems.
What am I missing ?
