In mbed-os/features/storage/kvstore/KVMap.h has the following macro
#define MAX_ATTACHED_KVS 3
I think this macro defines the max number of kvstore_main_instances attached to KVMap.
But in kv_config.cpp
static kvstore_config_t kvstore_config;
and all the _ storage_config_XXXXAPIs,such as
int _storage_config_filesystem_common()
ret =kv_map.attach(STR(MBED_CONF_STORAGE_DEFAULT_KV),& kvstore_config);
just can define only one kvstore_main_instance with the default partition name"/kv/",what if I need to define two or more kvstore_main_instances whose partition name should be different?
Can I modify the APIs such as
in kv_config.cpp?
