Building mbedtls for Android gives a few (similar) warnings. Here’s the first.
[ 38%] Built target mbedx509
Scanning dependencies of target mbedtls
[ 38%] Building C object library/CMakeFiles/mbedtls.dir/ssl_cache.c.o
[ 40%] Building C object library/CMakeFiles/mbedtls.dir/debug.c.o
[ 40%] Building C object library/CMakeFiles/mbedtls.dir/net_sockets.c.o
External/.build_area/mbedtls-2.16.3/library/net_sockets.c:332:37: warning: passing 'int *'
to parameter of type 'socklen_t *' (aka 'unsigned int *') converts between pointers to integer types with
different sign [-Wpointer-sign]
(void *) &type, &type_len ) != 0 ||
/Users/pi/Library/Android/sdk/ndk-bundle/toolchains/llvm/prebuilt/darwin-x86_64/sysroot/usr/include/sys/socket.h:311:92: note:
passing argument to parameter '__value_length' here
__socketcall int getsockopt(int __fd, int __level, int __option, void* __value, socklen_t* __value_length);
External/.build_area/mbedtls-2.16.3/library/net_sockets.c:342:80: warning: passing 'int *'
(struct sockaddr *) &client_addr, &n );
If I inspect External/.build_area/mbedtls-2.16.3/library/net_sockets.c:332:37 I see:
* Accept a connection from a remote client
int mbedtls_net_accept( mbedtls_net_context *bind_ctx,
mbedtls_net_context *client_ctx,
void *client_ip, size_t buf_size, size_t *ip_len )
int ret;
int type;
struct sockaddr_storage client_addr;
#if defined(__socklen_t_defined) || defined(_SOCKLEN_T) || \
defined(_SOCKLEN_T_DECLARED) || defined(__DEFINED_socklen_t)
socklen_t n = (socklen_t) sizeof( client_addr );
socklen_t type_len = (socklen_t) sizeof( type );
#else
int n = (int) sizeof( client_addr );
int type_len = (int) sizeof( type );
#endif
/* Is this a TCP or UDP socket? */
if( getsockopt( bind_ctx->fd, SOL_SOCKET, SO_TYPE,
(void *) &type, &type_len /* <-- warning is HERE */ ) != 0 ||
( type != SOCK_STREAM && type != SOCK_DGRAM ) )
return( MBEDTLS_ERR_NET_ACCEPT_FAILED );
… It appears that none of those four flags were defined:
^ These ones.
Does this mean I’m missing something in my build setup?
Should I be passing in one of these flags somehow?
Can anyone help me get traction on this problem?
