I’m trying to modify char array and noticed big problem with adding next chars to array. After 4 operations I can’t add next chars to the array. Here is the code.
The output is:
c
cc
ccc
cccc
cccc
cccc
cccc
cccc
cccc
cccc
insted of:
c
cc
ccc
cccc
ccccc
cccccc
ccccccc
cccccccc
ccccccccc
cccccccccc
Can you help me to find where is the problem with code?
Best regards
Maciek
Code:
// SERIAL PINS
static BufferedSerial dbg ( PA_9 , NC , 115200 ) ;
//DBG configuration
dbg.set_format( 8 , BufferedSerial::None , 1 ) ;
char* p = new char[10] ;
char c = 'c' ;
for ( int i = 0 ; i < 10 ; i++ )
p [ i ] = c ;
p [ i + 1 ] = '\0' ;
dbg.write ( "\r\n" , sizeof ( "\r\n" ) ) ;
dbg.write ( p , sizeof ( p ) ) ;
