Hello Alex,
- The
RS485 class, like the UnbufferedSerial, is derived from the SerialBase. However, the inheritance in this case is public.
- Added a new
Digitalout data-member _de (Driver Enabled - DE). On the hardware side it is assumed that the mbed _de pin is connected to (both) the DE and the /RE pins of the RS485 driver.
- Added new
RS485::enable_receiver member function.
- The
RS485::write member function calls the SerialBase::write function to ensure that the RS485::enable_receiver callback is get called on the SERIAL_EVENT_TX_COMPLETE event.
Please keep in mind that the code below has not been tested!
RS485.h:
* Copyright (c) 2019 ARM Limited
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
#ifndef RS485_H
#define RS485_H
#include "platform/platform.h"
#if DEVICE_SERIAL || defined(DOXYGEN_ONLY)
#include <cstdarg>
#include "drivers/SerialBase.h"
#include "platform/FileHandle.h"
#include "platform/mbed_toolchain.h"
#include "platform/NonCopyable.h"
#include "drivers/DigitalOut.h"
namespace mbed {
/** \defgroup drivers-public-api-uart UART
* \ingroup drivers-public-api
* \defgroup drivers_RS485 RS485 class
* \ingroup drivers-public-api-uart
* Class implementation for unbuffered I/O for an interrupt driven application
* or one that needs to have more control.
class RS485:
public SerialBase,
public FileHandle,
private NonCopyable<RS485> {
public:
* Create a serial port instance connected to the specified transmit and
* receive pins, with the specified baud rate.
* @param tx Transmit pin
* @param rx Receive pin
* @param baud The baud rate of the serial port (optional, defaults to MBED_CONF_PLATFORM_DEFAULT_SERIAL_BAUD_RATE)
* @note
* Either tx or rx may be specified as NC if unused
RS485(
PinName tx,
PinName rx,
PinName de, // Driver Enable (DE) pin connected to `not Receiver Enable` (/RE) pin
int baud = MBED_CONF_PLATFORM_DEFAULT_SERIAL_BAUD_RATE
/** Write the contents of a buffer to a file
* Blocks until all data is written
* @param buffer The buffer to write from
* @param size The number of bytes to write
* @return The number of bytes written
ssize_t write(const void *buffer, size_t size);
/** Read the contents of a file into a buffer
* Blocks and reads exactly one character
* @param buffer The buffer to read in to
* @param size The number of bytes to read
* @return The number of bytes read
ssize_t read(void *buffer, size_t size);
/** Move the file position to a given offset from from a given location
* Not valid for a device type FileHandle like RS485.
* In case of RS485, returns ESPIPE
* @param offset The offset from whence to move to
* @param whence The start of where to seek
* SEEK_SET to start from beginning of file,
* SEEK_CUR to start from current position in file,
* SEEK_END to start from end of file
* @return The new offset of the file, negative error code on failure
off_t seek(off_t offset, int whence = SEEK_SET) override
return -ESPIPE;
/** Get the size of the file
* @return Size of the file in bytes
off_t size() override
return -EINVAL;
/** Check if the file in an interactive terminal device
* @return True if the file is a terminal
* @return False if the file is not a terminal
* @return Negative error code on failure
int isatty() override
return true;
/** Close a file
* @return 0 on success, negative error code on failure
int close() override
return 0;
/** Enable or disable input
* Control enabling of device for input. This is primarily intended
* for temporary power-saving; the overall ability of the device to operate
* for input and/or output may be fixed at creation time, but this call can
* allow input to be temporarily disabled to permit power saving without
* losing device state.
* @param enabled true to enable input, false to disable.
int enable_input(bool enabled) override;
/** Enable or disable output
* Control enabling of device for output. This is primarily intended
* allow output to be temporarily disabled to permit power saving without
* @param enabled true to enable output, false to disable.
int enable_output(bool enabled) override;
/** Check for poll event flags
* Check the events listed in events to see if data can be read or written
* without blocking.
* Call is nonblocking - returns state of events.
* @param events bitmask of poll events we're interested in - POLLIN/POLLOUT etc.
* @returns bitmask of poll events that have occurred.
short poll(short events) const override;
using SerialBase::attach;
using SerialBase::baud;
using SerialBase::format;
using SerialBase::readable;
using SerialBase::writeable;
using SerialBase::IrqCnt;
using SerialBase::RxIrq;
using SerialBase::TxIrq;
using SerialBase::write; // make the private function available for the RS485 class
#if DEVICE_SERIAL_FC
// For now use the base enum - but in future we may have extra options
// such as XON/XOFF or manual GPIO RTSCTS.
using SerialBase::Flow;
// In C++11, we wouldn't need to also have using directives for each value
using SerialBase::Disabled;
using SerialBase::RTS;
using SerialBase::CTS;
using SerialBase::RTSCTS;
/** Set the flow control type on the serial port
* @param type the flow control type (Disabled, RTS, CTS, RTSCTS)
* @param flow1 the first flow control pin (RTS for RTS or RTSCTS, CTS for CTS)
* @param flow2 the second flow control pin (CTS for RTSCTS)
void set_flow_control(Flow type, PinName flow1 = NC, PinName flow2 = NC);
#endif // DEVICE_SERIAL_FC
private:
DigitalOut _de;
void enable_receiver(int event) { _de = 0; } // disable driver (enable receiver)
} // namespace mbed
#endif // DEVICE_SERIAL || defined(DOXYGEN_ONLY)
#endif // RS485_H
RS485.cpp:
* Copyright (c) 2006-2019 ARM Limited
#include "RS485.h"
#if DEVICE_SERIAL
#include "platform/mbed_critical.h"
namespace mbed {
RS485::RS485(
PinName tx,
PinName rx,
PinName de,
int baud
) : SerialBase(tx, rx, baud), _de(de)
_de = 0; // disable driver (enable receiver)
ssize_t RS485::write(const void *buffer, size_t size)
_de = 1; // enable driver (disable receiver)
const unsigned char *buf = static_cast<const unsigned char *>(buffer);
if (size == 0) {
return 0;
bool lock_api = !core_util_in_critical_section();
if (lock_api) {
lock();
for (size_t i = 0; i < size; i++) {
_base_putc(buf[i]);
if (lock_api) {
unlock();
SerialBase::write((const uint8_t*)buffer, size, callback(this, &RS485::enable_receiver), SERIAL_EVENT_TX_COMPLETE);
return size;
ssize_t RS485::read(void *buffer, size_t size)
unsigned char *buf = static_cast<unsigned char *>(buffer);
if (size == 0) {
return 0;
lock();
buf[0] = _base_getc();
unlock();
return 1;
short RS485::poll(short events) const
short revents = 0;
if (
(events & POLLIN)
&& (const_cast <RS485 *>(this))->SerialBase::readable()
revents |= POLLIN;
if (
(events & POLLOUT)
&& (const_cast <RS485 *>(this))->SerialBase::writeable()
revents |= POLLOUT;
return revents;
int RS485::enable_input(bool enabled)
SerialBase::enable_input(enabled);
return 0;
int RS485::enable_output(bool enabled)
SerialBase::enable_output(enabled);
return 0;
void RS485::set_flow_control(Flow type, PinName flow1, PinName flow2)
lock();
SerialBase::set_flow_control(type, flow1, flow2);
unlock();
} // namespace mbed
#endif // #if DEVICE_SERIAL
main.cpp:
#include "RS485.h"
DigitalOut led1(LED1);
RS485 rs485(PB_6, PA_6, PC_7, 115200); // Tx, Rx, DE, baud
char buf[] = "Hello, RS485.";
while(true)
led1 = !led1;
rs485.write(buf, sizeof(buf));
ThisThread::sleep_for(500ms);
