How to Dispatch EventQueues on Multiple Threads?
I want to dispatch two different eventqueue on two threads so that I can modify their priorities. They should toggle two led at different frequencies. However, only one of them would turn on. It seems that the OS never switches task even if I use ThisThread::yield(); . What am I missing here? Thanks in advance.
#define TASK1_FLAG 10
#define DELAY 5ms
#define MS_100 100
#define TASK2_FLAG 10
DigitalOut led2(LED2);
DigitalOut led3(LED3);
DigitalOut led4(LED4);
DigitalOut led1(LED1);
void Task1();
void Task2();
void Task3();
void Task4();
int main(void)
    Thread t1;
    Thread t2;
    EventQueue queue1(32*EVENTS_EVENT_SIZE);
    EventQueue queue2(32*EVENTS_EVENT_SIZE);
    t1.start(callback(&queue1, &EventQueue::dispatch_forever));
    queue1.call_every(1s,&Task1);
    queue1.dispatch_forever();
    t2.start(callback(&queue2, &EventQueue::dispatch_forever));
    queue2.call_every(2s,&Task2);
    queue2.dispatch_forever();
   return 0;
void Task1()
        led1=1;
        ThisThread::sleep_for(5ms);
        led1=0;
void Task2()
       led2 = 1;
       led2 = 0;
just try cutout queueX.dispatch_forever(); from your code, because you already do it in thread.start(...) and also you need to add while(1); to the end of main.
The LEDs wouldn’t turn on if I get rid of the dispatch_forever(); after calling queueX.call_every(); I tried to to modify it to the following code and lights are flashing but if change both queue1 and queue 2 to dispatch_once(); neither of the LEDs will turn on. I am not sure why.
Why do I need a while(1) inside of my main? Thank you!
//    queue1.dispatch_forever();
    queue1.dispatch_once();
You not need it, the associated thread do it for you. If you want to dispatch them by yourself then do not use threads. Check docs and examples of EventQueue - API references and tutorials | Mbed OS 6 Documentation
Without a while() at the end of the main, the program will leave the main and then the program ends.
Without that the main thread is terminated and goes out the scope. This results in deleting of all the variables declared/defined in it’s scope (i.e. t1, t2, queue1 and queue2).
If you declare/define them as global then the program should work without having an endless while loop inside the main function:
#define DELAY       5ms
#define MS_100      100
void        Task1();
void        Task2();
void        Task3();
void        Task4();
Thread      t1;
Thread      t2;
EventQueue  queue1(32 * EVENTS_EVENT_SIZE);
EventQueue  queue2(32 * EVENTS_EVENT_SIZE);
int main(void)
    queue1.call_every(1s, & Task1);
    queue2.call_every(2s, & Task2);
    //    while(1);
void Task1()
    led1 = 1;
    led1 = 0;
void Task2()
    led2 = 1;
    led2 = 0;
Thank you so much!! I never thought that the problem was my main thread terminated. It all makes sense now!
Thank you!! It is now working :slight_smile:
