In MbedOS 6+ is wait(1) function replaced with thread_sleep_for(1000) so
thread_sleep_for((0.8*interval[i]/10)*1000);
// same like
wait((0.8*interval[i]/10));
and it is a calculation how long the tone have to play.
// same like
@JohnnyK Do u have any idea like how we do next or previous button to control the song index?
It’s just a movement through a matrix tables. So you just increase and decrease song index.
// for next
song_index++; // increase song index
note = 0; // reset note idex
beat = 0; // reset beat idex
// for previous
song_index--; // decrease song index
@JohnnyK Thanks for the information. In addition, do u have any idea like how we place thread (Rtos) for lcd display inside udf? I saw mostly they place the thread at int main() but how do we know when it can run inside the udf, if i wan place the thread inside our udf for display like pause/resume , stop , play and so on.
For example: display the thread in my pause loop
With UDF you mean User Defined Function I suppose, but I am not sure I understand.
You want something like this?
void play(){
// a code for plaing a song
// Start a thread what will call a code for show PLAY string with a NAME of song on the display
Thanks for the information . I want to ask inside ISR can use if else statement?
Of course, you can use what do you want inside ISR, but you want to have it short as possible and nothing complicated. So you want to avoid use printf, delays, read a peripherals (UART, SPI, I2C…) and so on.
Usually is good to use a bool flag, same like with buttonPlayPress above, and process it in a thread or take it out of ISR context via EventQueue - API references and tutorials | Mbed OS 6 Documentation (first example)
Thanks for the information. Do mbed have goto function?
That has nothing together with Mbed, it is a feature of programing languages, in this case C++
goto statement - cppreference.com
hi @JohnnyK , for mbed rtos thread cannot use goto statement?
From my point of view you can use it every you want but it must be use very carefully.
What is the reason of usage? I think it is possible to it without that.
Mbed itself doesn’t directly interact with audio playback functionalities. However, you can achieve a similar effect for controlling song or ringtones playback using Mbed for user input and potentially other functionalities. Here’s a general approach:
1. User Input:
InterruptIn object connected to a button on your Mbed board.2. State Variable:
isPlaying) to track the playback state (playing or paused).3. Button Press Function:
isPlaying is true (playing):
isPlaying to false (paused).isPlaying is false (paused):
isPlaying to true (playing).4. Main Loop:
InterruptIn button(BUTTON1);
bool isPlaying = false;
void buttonPress() {
if (isPlaying) {
isPlaying = false;
// Implement logic to pause audio playback (replace with your specific method)
} else {
isPlaying = true;
// Implement logic to resume audio playback (replace with your specific method)
button.fall(callback(&buttonPress));
while (1) {
// You can display the playback state or perform other actions here
if (isPlaying) {
// Display “Playing”
} else {
// Display “Paused”
