How to use multiple flags for intra-thread signaling?
I am trying to understand how intra-thread signaling work in Mbed RTOS. Multiple functions such as:
uint32_t flags_wait_all (uint32_t flags, bool clear=true)
uint32_t flags_set (uint32_t flags)
accept one uint32_t as parameter as multiple flags.
How does this work? Each flag use one bit of the 32 bit parameter? Or some combination bits?
Will something like the following work?
#define THREAD_SIGNALING_FLAG_1 1
#define THREAD_SIGNALING_FLAG_2 2
#define THREAD_SIGNALING_FLAG_3 4
Please forgive me if I missed something obvious. Thanks.
Hello Li,
Each flag is using one of the last 31 bits of of the EventFlags variable. The most significant is not used.
  • I usually first define the flag’s position within the EventFlags variable, for example:
#define MOTOR_FLAG        (1UL << 0)    // position 0
#define MAX_SPEED_FLAG    (1UL << 1)    // position 1
#define RELAY_ON_FLAG     (1UL << 8)    // position 8
  • Then I can set the selected flag(s) in the program like:
EventFlags evenFlags;
evenFlags.set(MAX_SPEED_FLAG);
evenFlags.set(MOTOR_FLAG | MAX_SPEED_FLAG)
  • After that I can wait and block some thread until the selected flag(s) become(s) set:
eventFlags.wait_any(MOTOR_FLAG | RELAY_ON_FLAG);
eventFlags.wait_all(MOTOR_FLAG | MAX_SPEED_FLAG);
  • By default the wait function clears the flags passed to it. If you don’t want the wait function to clear the flag(s) then pass it a second argument defining the wait time in millisecond and third one equal to false:
eventFlags.wait_all(MOTOR_FLAG | MAX_SPEED_FLAG,  osWaitForever, false);
  • Below is an example how to use them in program:
#define SAMPLE_FLAG1    (1UL << 0)
#define SAMPLE_FLAG2    (1UL << 1)
DigitalOut      led1(LED1, 0);
DigitalOut      led2(LED2, 0);
EventFlags      event_flags;
osThreadId_t    threadId;
uint32_t    flags_read = 0;
Thread      thread_01;
Thread      thread_02;
void task_01()
    while (true) {
        led1 = 1;
        event_flags.set(SAMPLE_FLAG1);
        ThisThread::sleep_for(500ms);
        led1 = 0;
        event_flags.set(SAMPLE_FLAG2);
void task_02()
    while (true) {
        event_flags.wait_all(SAMPLE_FLAG1);
        led2 = 1;
        event_flags.wait_all(SAMPLE_FLAG2);
        led2 = 0;
    event_flags.clear();
    thread_01.start(callback(task_01));
    thread_02.start(callback(task_02));
    printf("Waiting for any flag.\r\n");
    while (true) {
        flags_read = event_flags.wait_any(SAMPLE_FLAG1 | SAMPLE_FLAG2, osWaitForever, true);
        printf("Got: 0x%.04x\r\n", flags_read);
        printf("led1 = %d\r\n", led1.read());
        printf("led2 = %d\r\n", led2.read());
Can you use constexpr instead of macros to define the flags?
Yes, we can. Actually it’s a better solution because unlike defines constant expressions are check at compile time:
const uint32_t MOTOR_FLAG     = (1UL << 0);    // position 0
const uint32_t MAX_SPEED_FLAG = (1UL << 1);    // position 1
const uint32_t RELAY_ON_FLAG  = (1UL << 8);    // position 8
EventFlags can also be very effectively used to handle interrupts:
// Define event flags.
const uint32_t INTERRUPT_FLAG = (1UL << 0);  // position 0
// Define global variables
InterruptIn button(p22);
// The following function is called on interrupt.
// It is as short as possible (to not blocking) .
void  on_iterrupt()
    eventFlags.set(INTERRUPT_FLAG);
// The next task is an Interrupt Service Routine and
// it is running in a high priority task.
// It is blocking/waiting for the INTERRUPT_FLAG to become set.
void interrupt_service_routine()
    while (1) {
        eventFlags.wait_all(INTERRUPT_FLAG);
        // serving the interrupt
Thread thread_isr(osPriorityHigh);
    // Start the interrupt service routine task
    // in a high priority task.
    thread_isr.start(callback(interrupt_service_routine);
    // Attach a callback to the interrupt.
    button.fall(on_iterrupt);
    // The main thread
    while(1) {
Have a look also at API Can lose messages - #2 by hudakz .
