How to select a specific i2c interface
I am new to mbed os. I imported this ds2482 library:
I use a nucleo-767zi board and want to use the i2c4 connected to D2/PF_15 and D4/PF_14.
There is only a spike in the scl line, but not happens really.
I guess I2C i2c (D2, D4); is not working here?
Actually I am looking for the documentatio how to configure the target in this case, like what I normally would do with CubeMX.
The online compiler did not create a .json file in the root for this.
Hello Kopke,
You are right. To select I2C4 on a NUCLEO-F767ZI board it’s enough to create an I2C object with two arguments - the associated SDA and the SCL pin names:
I2C  i2c(D2, D4);
The I2C Mbed documentation is available here.
All the hard work of the initialization and settings is done by Mbed as follows:
The I2C constructor is implemented in I2C.cpp.
I2C::I2C(PinName sda, PinName scl) :
#if DEVICE_I2C_ASYNCH
    _irq(this), _usage(DMA_USAGE_NEVER), _deep_sleep_locked(false),
#endif
    _i2c(), _hz(100000)
    lock();
    // The init function also set the frequency to 100000
    _sda = sda;
    _scl = scl;
    recover(sda, scl);
    i2c_init(&_i2c, _sda, _scl);
    // Used to avoid unnecessary frequency updates
    _owner = this;
    unlock();
The constructor calls the i2c_init(&_i2c, _sda, _scl) function for the selected target (in your case the STM boards) implemented in i2c_api.c.
void i2c_init(i2c_t *obj, PinName sda, PinName scl)
    struct i2c_s *obj_s = I2C_S(obj);
    // Determine the I2C to use
    I2CName i2c_sda = (I2CName)pinmap_peripheral(sda, PinMap_I2C_SDA);
    I2CName i2c_scl = (I2CName)pinmap_peripheral(scl, PinMap_I2C_SCL);
    obj_s->sda = sda;
    obj_s->scl = scl;
    obj_s->i2c = (I2CName)pinmap_merge(i2c_sda, i2c_scl);
    MBED_ASSERT(obj_s->i2c != (I2CName)NC);
#if defined I2C1_BASE
    // Enable I2C1 clock and pinout if not done
    if (obj_s->i2c == I2C_1) {
        obj_s->index = 0;
        __HAL_RCC_I2C1_CLK_ENABLE();
        // Configure I2C pins
        obj_s->event_i2cIRQ = I2C1_EV_IRQn;
        obj_s->error_i2cIRQ = I2C1_ER_IRQn;
#endif
#if defined I2C2_BASE
    // Enable I2C2 clock and pinout if not done
    if (obj_s->i2c == I2C_2) {
        obj_s->index = 1;
        __HAL_RCC_I2C2_CLK_ENABLE();
        obj_s->event_i2cIRQ = I2C2_EV_IRQn;
        obj_s->error_i2cIRQ = I2C2_ER_IRQn;
#endif
#if defined I2C3_BASE
    // Enable I2C3 clock and pinout if not done
    if (obj_s->i2c == I2C_3) {
        obj_s->index = 2;
        __HAL_RCC_I2C3_CLK_ENABLE();
        obj_s->event_i2cIRQ = I2C3_EV_IRQn;
        obj_s->error_i2cIRQ = I2C3_ER_IRQn;
#endif
#if defined I2C4_BASE
    if (obj_s->i2c == I2C_4) {
        obj_s->index = 3;
        __HAL_RCC_I2C4_CLK_ENABLE();
        obj_s->event_i2cIRQ = I2C4_EV_IRQn;
        obj_s->error_i2cIRQ = I2C4_ER_IRQn;
#endif
#if defined FMPI2C1_BASE
    if (obj_s->i2c == FMPI2C_1) {
        obj_s->index = 4;
        __HAL_RCC_FMPI2C1_CLK_ENABLE();
        obj_s->event_i2cIRQ = FMPI2C1_EV_IRQn;
        obj_s->error_i2cIRQ = FMPI2C1_ER_IRQn;
#endif
    pinmap_pinout(sda, PinMap_I2C_SDA);
    pinmap_pinout(scl, PinMap_I2C_SCL);
    pin_mode(sda, OpenDrainNoPull);
    pin_mode(scl, OpenDrainNoPull);
    // I2C configuration
    // Default hz value used for timeout computation
    if (!obj_s->hz) {
        obj_s->hz = 100000;    // 100 kHz per default
    // Reset to clear pending flags if any
    i2c_hw_reset(obj);
    i2c_frequency(obj, obj_s->hz);
#if DEVICE_I2CSLAVE
    // I2C master by default
    obj_s->slave = 0;
    obj_s->pending_slave_tx_master_rx = 0;
    obj_s->pending_slave_rx_maxter_tx = 0;
#endif
    // I2C Xfer operation init
    obj_s->event = 0;
    obj_s->XferOperation = I2C_FIRST_AND_LAST_FRAME;
#ifdef I2C_IP_VERSION_V2
    obj_s->pending_start = 0;
#endif
After that you can change the frequency from the default 100 kHz to whatever your need by calling the I2C class’ frequency method:
i2c.frequency(new_frequency);
which is implemented in I2C.cpp.
void I2C::frequency(int hz)
    lock();
    _hz = hz;
    // We want to update the frequency even if we are already the bus owners
    i2c_frequency(&_i2c, _hz);
    // Updating the frequency of the bus we become the owners of it
    _owner = this;
    unlock();
The frequency method calls the i2c_frequency(&_i2c, _hz) function which is for STM targets implemented in i2c_api.c.
void i2c_frequency(i2c_t *obj, int hz)
    int timeout;
    I2C_HandleTypeDef *handle = &(obj_s->handle);
    // wait before init
    timeout = BYTE_TIMEOUT;
    while ((__HAL_I2C_GET_FLAG(handle, I2C_FLAG_BUSY)) && (--timeout != 0));
#ifdef I2C_IP_VERSION_V1
    handle->Init.ClockSpeed      = hz;
    handle->Init.DutyCycle       = I2C_DUTYCYCLE_2;
#endif
    /*  Only predefined timing for below frequencies are supported */
    MBED_ASSERT((hz == 100000) || (hz == 400000) || (hz == 1000000));
    handle->Init.Timing = get_i2c_timing(hz);
    // Enable the Fast Mode Plus capability
    if (hz == 1000000) {
#if defined(I2C1_BASE) && defined(__HAL_SYSCFG_FASTMODEPLUS_ENABLE) && defined (I2C_FASTMODEPLUS_I2C1)
            HAL_I2CEx_EnableFastModePlus(I2C_FASTMODEPLUS_I2C1);
#endif
#if defined(I2C2_BASE) && defined(__HAL_SYSCFG_FASTMODEPLUS_ENABLE) && defined (I2C_FASTMODEPLUS_I2C2)
            HAL_I2CEx_EnableFastModePlus(I2C_FASTMODEPLUS_I2C2);
#endif
#if defined(I2C3_BASE) && defined(__HAL_SYSCFG_FASTMODEPLUS_ENABLE) && defined (I2C_FASTMODEPLUS_I2C3)
            HAL_I2CEx_EnableFastModePlus(I2C_FASTMODEPLUS_I2C3);
#endif
#if defined(I2C4_BASE) && defined(__HAL_SYSCFG_FASTMODEPLUS_ENABLE) && defined (I2C_FASTMODEPLUS_I2C4)
            HAL_I2CEx_EnableFastModePlus(I2C_FASTMODEPLUS_I2C4);
#endif
#endif //I2C_IP_VERSION_V2
    /*##-1- Configure the I2C clock source. The clock is derived from the SYSCLK #*/
#if defined(I2C1_BASE) && defined (__HAL_RCC_I2C1_CONFIG)
        __HAL_RCC_I2C1_CONFIG(I2CAPI_I2C1_CLKSRC);
#endif
#if defined(I2C2_BASE) && defined(__HAL_RCC_I2C2_CONFIG)
        __HAL_RCC_I2C2_CONFIG(I2CAPI_I2C2_CLKSRC);
#endif
#if defined(I2C3_BASE) && defined(__HAL_RCC_I2C3_CONFIG)
        __HAL_RCC_I2C3_CONFIG(I2CAPI_I2C3_CLKSRC);
#endif
#if defined(I2C4_BASE) && defined(__HAL_RCC_I2C4_CONFIG)
        __HAL_RCC_I2C4_CONFIG(I2CAPI_I2C4_CLKSRC);
#endif
#ifdef I2C_ANALOGFILTER_ENABLE
    /* Enable the Analog I2C Filter */
    HAL_I2CEx_ConfigAnalogFilter(handle, I2C_ANALOGFILTER_ENABLE);
#endif
    handle->Init.AddressingMode  = I2C_ADDRESSINGMODE_7BIT;
    handle->Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
    handle->Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
    handle->Init.NoStretchMode   = I2C_NOSTRETCH_DISABLE;
    handle->Init.OwnAddress1     = 0;
    handle->Init.OwnAddress2     = 0;
    HAL_I2C_Init(handle);
    /*  store frequency for timeout computation */
    obj_s->hz = hz;
