I want to use 5MHz uart, compiling with Visual Studio Code + Platform IO. My board us Nucleo-F303RE
I can set 4.5MHz, but 5MHz is not available.
Hello Igor
- Create a project for the STM32F303 microcontroller in the STM32CubeIDE. It’s quite slow, as everything built with Java, so be patient.
- Open the
*.ioc
file and with theDevice Configuration Tool
and try to set the same system clock configuration as used by Mbed in the following file:
mbed-os/targets/TARGET_STM/TARGET_STM32F3/TARGET_STM32F303xE/system_clock.c
- Try to configure the UART (to set the 5MHz bit rate) with the
. If it’s impossible then I’m afraid there is no solution to your request. Otherwise, let the STM32CubeIDE generate the code (header and source files). - Try to find the related UART initialization code in the generated files and
copy & paste
it (the related sections) to your Mbedmain.cpp
. Don’tcopy & paste
the system clock configuration code sections since that has been already included into the project in thesystem_clock.c
file by Mbed.
