I want to read temperature from TMP006 and send data to terminal using bluetooth. I am able to read temperature without any problem, and I can also send random character or string using bluetooth. But when I try to combine these features, there is no output. From my understanding the problem is when I define TMP006. Following is my code. Can somebody please point out where I’m making mistake. Thank you in advance.
#include “mbed.h” #include “TMP006.h”
#define Address 0x80
Serial rn41(p9,p10); //name the serial port rn41
TMP006 sensor(p12, p13, Address);
rn41.baud(115200); // set baud for RN41
while (1) {
Hi Jan, I’m using LPC1768 as the embedded system and a regular plain application board(no name). What do you suggest in case of data bus collision?
Thank you
Also for what it’s worth. The hardware isn’t causing the collision. If I commented out the //TMP006 sensor(…) part and the subsequent codes involving TMP006, then the program works fine being able to use bluetooth and all.
Serial pins are on same pins like I2C above and also on pins P13-14
In you constructor I see
If I understand it correctly the TMP006 use SMBUS which is I2C.
Are you sure your pins of the sensor object are correct?
The idea about collision was about, when you use 2 interfaces what are shared on multiple pins what you use for different tasks, can lead to problems… Maybe I am wrong.
You are absolutely correct. I had just gotten it work using pin 28 and 27 and I saw this notification. It’s working perfectly now. Thank you for your time and help Jan. Have a great day.
