I am having some really weird issue, can anyone offer a fresh look and see if there is anything obvious I am missing?
I have this function that grabs data from CircularBuffer byte by byte and check if incoming data matches certain pattern, until either the CircularBuffer is empty or a matching pattern is found.
bool CC13XX::packetAvailable()
uint8_t newByte;
bool pktAvail = false;
while(uartRxBuf.pop(newByte)) {
pktAvail = processByte(newByte);
printf("NB %02X, Result: %C\n", newByte, pktAvail ? 'Y' : 'N');
if(pktAvail) {
processPacket();
break;
if(pktAvail) {
printf("Return should be true\n");
// Return as seen in main when called
// Is almost always false
return pktAvail;
This function is called in main every 100ms. If return is true, then some debug tag is print out to console.
if(cc13xx.packetAvailable()) {
printf("CC13XX Packet Received\n");
The problem I am having is, return by cc13xx.packetAvailable() is almost always false, even when the expected return is true as indicated by printf() inside the function.
I feel the problem I am having is related to C++ itself or compiler, but I am not quite sure where it really is.
Thanks in advance.
