I am trying to configure a custom test board I have using a F044K6 board. I have a button on the custom board that when pressed I want to trigger an I2C transaction. I am using InterruptIn and it does trigger the I2C interface to start but the entire transaction doesn’t complete. Just the first word goes out. If I use the button as a DigitalIn, the process works fine although the switch is slow to respond. That is why I want to use the InterrupIn. I assume the ISR process is conflicting with the I2C interface but not sure how to fix it.
void set_brightness(char BRIGHT) {
data_write[0] = PWM_REG_16;
data_write[1] = BRIGHT;
i2c.write(LWADD, data_write, 2, 0);
data_write[0] = PWM_REG_3;
data_write[0] = UPDATE;
data_write[1] = 0x00;
void test_sequence(void) {
n++;
testseq = 0;
if (n <= NUM_TEST) {
if(n == 1) {
set_brightness(0x19);
testseq = 1;
wait(1);
testseq = 0;
pc.printf("%d\n", n);
else if (n == 2) {
set_brightness(0x80);
testseq = 1;
wait(1);
testseq = 0;
else if (n == 3) {
set_brightness(0xE6);
testseq = 1;
wait(1);
testseq = 0;
else if (n == 4) {
set_channel(LED_CTRL_1);
testseq = 1;
wait(1);
testseq = 0;
else if (n == 5) {
set_channel(LED_CTRL_2);
testseq = 1;
wait(1);
testseq = 0;
else if (n == 6) {
set_channel(0xFF);
testseq = 1;
wait(1);
testseq = 0;
else {
return;
else {
pc.printf(“Test Complete\r\n”);
return;
/* Configure the LED Driver */
int placeholder;
data_write[0] = CONFIG_REG;
int status = i2c.write(LWADD, data_write, 2, 0);
if (status != 0) { // Error
while (1) {
myled = !myled;
wait(0.2);
testpass = 1; //initialize "TEST PASS" LED
testseq = 1; //initialize the Blue LED on the test sequence button
n = 0;
testinc.mode (PullUp);
testinc.fall(&test_sequence);
