Hi. I’m trying to use a Max11040K ADC with an IRQ data output with LPC1768, but am having problems.
Issue is, whenever I enable the ISR (to read the falling edge of the ADC’s data output ready signal), the ISR says I cannot use the ADC’s IRQ within the ISR because of mutex. But, I’m kinda stuck with both LPC1768 and MAX11040K. I’ve been trying to get a workaround that’ll let me get 2k samples per second, but to no avail. Can anyone help? I can post the code snippets if needed.
Hi! Thanks for the answer. I used the flag trick, both with normal flags and EventFlags, but they kinda got too slow or were unstable. I wasn’t successful at using EventQueue,
I’ll try Bare Metal though, thanks!
I’m open to any other suggestions while I try this.
UPDATE: Sadly after some research I figured out I can’t use Bare Metal, I need to have an ethernet interface. Since NetworkInterface is not supported by Bare Metal, I can’t use it. Any help or pseudocodes would be appreciated.
