using mbedtls2.7.6
I am trying to set up ssl_server2 from examples with simple openssl client using bp256r1 cert/keys on both sides.
ssl_tls.c:4329: |2| <= send alert message
ssl_tls.c:6859: |2| <= handshake
failed
! mbedtls_ssl_handshake returned -0x6980
Last error was: -27008 - SSL - None of the common ciphersuites is usable (eg, no suitable certificate, see debug messages)
Connection is not established due to not supported cipher suites in server cert.
Allowed curves:
//#define MBEDTLS_ECP_DP_SECP192R1_ENABLED
//#define MBEDTLS_ECP_DP_SECP224R1_ENABLED
#define MBEDTLS_ECP_DP_SECP256R1_ENABLED
#define MBEDTLS_ECP_DP_SECP384R1_ENABLED
//#define MBEDTLS_ECP_DP_SECP521R1_ENABLED
//#define MBEDTLS_ECP_DP_SECP192K1_ENABLED
//#define MBEDTLS_ECP_DP_SECP224K1_ENABLED
//#define MBEDTLS_ECP_DP_SECP256K1_ENABLED
#define MBEDTLS_ECP_DP_BP256R1_ENABLED
#define MBEDTLS_ECP_DP_BP384R1_ENABLED
#define MBEDTLS_ECP_DP_BP512R1_ENABLED
//#define MBEDTLS_ECP_DP_CURVE25519_ENABLED
Furthermore:
#define MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED
In the next step I tried without setting cert/keys (use polarssl defaults) and connection was successfull.
Following nmap output looks the same for both cases:
Checking available cipher suites of ssl_server with server
$ nmap --script ssl-enum-ciphers -p 4433 0.0.0.0
Starting Nmap 7.60 ( https://nmap.org ) at 2019-03-12 17:05 CET
Nmap scan report for 0.0.0.0
Host is up (0.00011s latency).
PORT STATE SERVICE
4433/tcp open vop
| ssl-enum-ciphers:
| TLSv1.2:
| ciphers:
| TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 (brainpoolP512r1) - A
| TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 (brainpoolP512r1) - A
| TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA (brainpoolP512r1) - A
| TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (brainpoolP512r1) - A
| TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 (brainpoolP512r1) - A
| TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA (brainpoolP512r1) - A
| compressors:
| NULL
| cipher preference: server
|_ least strength: A
I tried reducing the allowed curves to desired BP256R1 only:
Allowed curves:
//#define MBEDTLS_ECP_DP_SECP256R1_ENABLED
//#define MBEDTLS_ECP_DP_SECP384R1_ENABLED
//#define MBEDTLS_ECP_DP_BP384R1_ENABLED
//#define MBEDTLS_ECP_DP_BP512R1_ENABLED
Server is not starting due to following error:
programs/ssl/ssl_server2
. Seeding the random number generator... ok
. Loading the CA root certificate ... failed
! mbedtls_x509_crt_parse returned -0x3a00
Last error was: -0x3A00 - PK - Elliptic curve is unsupported (only NIST curves are supported)
But nmap now at least displays:
Starting Nmap 7.60 ( https://nmap.org ) at 2019-03-12 18:33 CET
Host is up (0.000064s latency).
PORT STATE SERVICE
4433/tcp open vop
| ssl-enum-ciphers:
| TLSv1.2:
| ciphers:
| TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 (brainpoolP256r1) - A
| TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 (brainpoolP256r1) - A
| TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA (brainpoolP256r1) - A
| TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (brainpoolP256r1) - A
| TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 (brainpoolP256r1) - A
| TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA (brainpoolP256r1) - A
| compressors:
| NULL
|_ least strength: A
I like to know why…
1)… cipher suite selection when not using default certificates fails (can provide more dbg output)
2)… nmap is only displaying bp512r1 curves - or not displaying bp256r1 curves
3)… allowing bp256r1 only is giving error "Elliptic curve is unsupported "
moatze
