L432kc uart with xbee
hello,i use a l432kc component and i need to communicate with a xbee s2c through UART and i don’t know what is wrong with my program ,some one can help me?
I correctly have connected the pins to the l432kc (Pin1xbee(3v3),Pin2xbee(txl432kc),Pin3xbee(rxl432kc),Pin10xbee(gnd)
here’s my program
  • Copyright (c) 2019 ARM Limited
  • SPDX-License-Identifier: Apache-2.0
#include “mbed.h”
#include “platform/mbed_thread.h”
#define BLINKING_RATE_MS 1000
RawSerial pc(USBTX,USBRX);
RawSerial xbee(PA_9,PA_10);
char car_recu;
bool ok;
void callback_ex()
// Note: you need to actually read from the serial to clear the RX interrupt
car_recu=(xbee.getc());
ok=true;
// led = !led;
pc.baud(9600);
xbee.baud(9600);
while (true) {
    thread_sleep_for(BLINKING_RATE_MS);
    xbee.printf("+++");
    while (true) {
        if (ok==true) {
            pc.putc(car_recu);
            ok=false;
     pc.printf("+++");
    thread_sleep_for(5000);
Hi there,
please be so kind and fill these three symbols ``` before and after your code for correct formating. You can edit your post via pen icon.
I do not know what you exactly want from your code but
    while (true) {
        if (ok==true) {
            pc.putc(car_recu);
            ok=false;
   // everything below will not be executed because of endless loop above
     pc.printf("+++");
Without interrupts and for both direction it can be something like that maybe
while(true){
   if(xbee.readable()){
      pc.putc(xbee.getc());
   if(pc.readable()){
      xbee.putc(pc.getc());
