Hello, I have been using the web compiler 1.10.25.0 to burn example projects to a Numaker M263A https://direct.nuvoton.com/en/numaker-iot-m263a
I want to create a UART between an Ardiuno Uno and this board. Can someone please help get me started with the code?
I have been playing around with something like this for the Nuvoton board, but someone suggested it may be old:
// Create a DigitalOutput object to toggle an LED whenever data is received.
static DigitalOut led(LED1);
// Create a BufferedSerial object with a default baud rate.
static Serial serial_port(D0, D1);
int main(void)
if (serial_port.readable())//compilation error here {
char data_rec = serial_port.read();// and here
if (data_rec == '1') digitalWrite(led, HIGH);
if (data_rec == '0') digitalWrite(led, LOW);
I want to use the Ardiuno Uno compatible extension connector.
Any help is greatly appreciated!
Eric
