Hi, is there a way to track the memory usage in mbed OS? I need this information to choose the optimal stack and heap size for my target.
Thank you
ualloc contains tracking debug, please have a look at ualloc module, which has this code inside:
UALLOC_DEBUG_LOG is effectively reserved for tracing memory allocations
Tracing must be enabled via "yotta config":
"debug": {
"options": {
"memory-trace": true
[TODO]: ualloc_debug_level probably needs better control with "yotta config"
#ifdef YOTTA_CFG_DEBUG_OPTIONS_MEMORY_TRACE
const UAllocDebug_t ualloc_debug_level = UALLOC_DEBUG_LOG;
#else
const UAllocDebug_t ualloc_debug_level = UALLOC_DEBUG_NONE;
#endif
Stack is used for static memory allocation and Heap for dynamic memory allocation, both stored in the computer’s RAM . More about…Stack and Heap
Brian
