I’m developing some Arduino libraries for a Portenta Machine Control (which use mbed os) which will use thread creation and mutex, etc…
I found by chance that within Arduino libraries is possible to create thread and handle operating system object (semaphore, mutex, etc) using also CMSIS interface which is the one of Keil (and from what I’ve understood mbedos is based on Keil)
At this point is it safe to use CMSIS API (c language) while on mbedos? Or it will be better to use MbedOS API (c++ language) ??
I have some source code which is already running with CMSIS and it can be ported without much efforts by simply using CMSIS calls… but I don’t know if it’s safe to use it on mbedOS (even if it compiles without error/warning)
What do you suggest me? Thank you
