Dear All
We are using mbedtls ssl_client2 and ssl_server2 examples with cert chain of root,intermediate and device.
Please refer earlier conversation as per below link My own sample rootCA is failing on handshaking with aws.
We have created a new topic as per earlier request.
We have hard-coded root ca ,intermediate(Server) and device(client) certs and keys in certs.c file.
Please let us know if any additional information is required.
Hi @manish_arm
Thank you for posting a new topic.
As questioned in the original topic, What is the “own key” You have set in the client side?
Could you please share logs?
Hi Manish,
You don’t need to replace the certificates in keys in certs.c. This file holds test certificates used by Mbed TLS.
You should use your own certificates and keys, by parsing them, whether with mbedtls_x509_crt_parse() or with mbedtls_x509_crt_parse_file(). For keys, you should parse with mbedtls_pk_parse_key().
If you are using the sslclient2 example, you can send these as parameters to the example application.
As for the logs, they are not accessible; Please paste the logs as text.
Hi Manish,
The root CA should not be sent as part of the certificate chain in the handshake.
It should be set as a trusted certificate using mbedtls_ssl_conf_ca_chain() (or mbedtls_ssl_conf_ca_cb()). From the logs, I understand that you have set two way authentication method, that the server requires client certificate verification. Was this your intention?
The failure is when the server tries to verify the client certificate. It is probably because the public key used for verification is not the pair of the private key that signed the certificate.
MBEDTLS_X509_BADCERT_EXT_KEY_USAGE is returned when the call for [mbedtls_x509_crt_check_extended_key_usage()] (https://github.com/ARMmbed/mbedtls/blob/development/library/ssl_tls.c#L7075). THis function fails, if the extended key usage doesn’t have the ANY usage, or MBEDTLS_OID_SERVER_AUTH for server, and MBEDTLS_OID_CLIEWNT_AUTH for client. (Inn case this extension exists)
In your working logs, I don’t see any extended key usage extension. However, t seems that the server certificate being sent is actually the intermediate certificate.
Please verify you have setr the correct server certificate, and that it has the correct extended jey usage extension.
Hi @manish_arm
The server certificate should not be an intermediate certificate.
It should not have a CA: true basic constraint.
In addition, it should b=not be the parent of the device certificate ( as it seems this is hte case here)
The device certificate in your working logs doesn’t have this extension, but if your failed case has the “TLS Web Server Authentication” extended key usage, then this is the reason for failure. It should wither have the MBEDTLS_OID_CLIENT_AUTH extended key usage, or the MBEDTLS_OID_ANY_EXTENDED_KEY_USAGE
