I am testing with ssl_server.c and config-suite-b.h but slightly modified for RSA key exchange instead of ECDSA (without modification, ECDSA is successful on the server but takes so long that the client times-out).
After modifying config-suite-b.h for RSA key exchange, mbedtls_x509_crt_parse fails and returns MBEDTLS_ERR_PK_INVALID_PUBKEY -0x3B00.
Why would the test certificate failing? Perhaps I have missed something when changing from ECDSA to RSA? Or is it related to disabled entropy?
The modified config-suite-b.h follows…
#define MBEDTLS_PLATFORM_C
/* System support */
#define MBEDTLS_HAVE_ASM
#define MBEDTLS_HAVE_TIME
* Minimal configuration for TLS NSA Suite B Profile (RFC 6460)
* Distinguishing features:
* - no RSA or classic DH, fully based on ECC
* - optimized for low RAM usage
* Possible improvements:
* - if 128-bit security is enough, disable secp384r1 and SHA-512
* - use embedded certs in DER format and disable PEM_PARSE_C and BASE64_C
* See README.txt for usage instructions.
/* mbed TLS feature support */
#define MBEDTLS_ECP_DP_SECP256R1_ENABLED
#define MBEDTLS_ECP_DP_SECP384R1_ENABLED
#define MBEDTLS_PKCS1_V15
//#define MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED
#define MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED
#define MBEDTLS_SSL_PROTO_TLS1_2
/* mbed TLS modules */
#define MBEDTLS_AES_C
#define MBEDTLS_ASN1_PARSE_C
#define MBEDTLS_ASN1_WRITE_C
#define MBEDTLS_BIGNUM_C
#define MBEDTLS_CIPHER_C
#define MBEDTLS_CTR_DRBG_C
#define MBEDTLS_ECDH_C
//#define MBEDTLS_ECDSA_C
#define MBEDTLS_ECP_C
#define MBEDTLS_ENTROPY_C
#define MBEDTLS_GCM_C
#define MBEDTLS_MD_C
#define MBEDTLS_MD5_C
//#define MBEDTLS_NET_C
#define MBEDTLS_OID_C
#define MBEDTLS_PK_C
#define MBEDTLS_PK_PARSE_C
#define MBEDTLS_RSA_C
#define MBEDTLS_SHA256_C
#define MBEDTLS_SHA512_C
//#define MBEDTLS_SSL_CLI_C
#define MBEDTLS_SSL_SRV_C
#define MBEDTLS_SSL_TLS_C
#define MBEDTLS_X509_CRT_PARSE_C
#define MBEDTLS_X509_USE_C
/* For test certificates */
#define MBEDTLS_BASE64_C
#define MBEDTLS_CERTS_C
#define MBEDTLS_PEM_PARSE_C
/* Save RAM at the expense of ROM */
#define MBEDTLS_AES_ROM_TABLES
/* Save RAM by adjusting to our exact needs */
#define MBEDTLS_ECP_MAX_BITS 384
#define MBEDTLS_MPI_MAX_SIZE 48 // 384 bits is 48 bytes
/* Save RAM at the expense of speed, see ecp.h */
#define MBEDTLS_ECP_WINDOW_SIZE 2
#define MBEDTLS_ECP_FIXED_POINT_OPTIM 0
/* Significant speed benefit at the expense of some ROM */
#define MBEDTLS_ECP_NIST_OPTIM
* You should adjust this to the exact number of sources you're using: default
* is the "mbedtls_platform_entropy_poll" source, but you may want to add other ones.
* Minimum is 2 for the entropy test suite.
//#define MBEDTLS_ENTROPY_MAX_SOURCES 2
#define MBEDTLS_NO_PLATFORM_ENTROPY
#define MBEDTLS_NO_DEFAULT_ENTROPY_SOURCES
#define MBEDTLS_TEST_NULL_ENTROPY // *** TESTING - REMOVE FOR PRODUCTION ***
/* Save ROM and a few bytes of RAM by specifying our own ciphersuite list */
#define MBEDTLS_SSL_CIPHERSUITES \
MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, \
MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
#define MBEDTLS_SSL_OUT_CONTENT_LEN 8192
