I’m using an mbed to bit-bang a PWM signal to a H bridge. I’ve got 2 outputs called TRT_MTR and INV_TRT_MTR (which is TRT_MTR inverted) which are configured as digital outputs. I’ve used a header file to contain my pin allocations, and then using a cpp file to manipulate them. I’m getting compile error that TRT_MTR is declared in the Traction cpp file, and the main cpp file (error code L6200E). As I’m using a header file TRT_MTR is not declared in either the Traction cpp file or the main cpp file.
I haven’t downloaded the code to my Mbed LPC1768 as it won’t compile yet.
I’m unsure of where my error is.
Thanks
Rob
