Just started using mbed for the first time. Able to build an app and connect to The Things Network and send data via LoraWan (although the initial connection takes a few attempts) through a custom board…
The issue I’m having is compiling in support for USBSerial. After adding USBDEVICE to mbed_app.json I’m getting 7 errors, all in the area of USBPhy_STM32.cpp. e.g. “no member named ‘DIEPTXF0_HNPTXFSIZ’ in ‘USB_TypeDef’”. I’ve updated targets.json as my Murata module has a STM32L072 not an STM32L082.
Not convinced the ordinary UART serial is working either (does compile though) but will test further.
Any ideas on the USB_TypeDef compile errors? Has support for the Murata module been fully added?
I have the exact same problem. From what I understand, USBSerial is actually not supported
on STM32L0xx. There is someone from ST Microelectronics who seems to be working on this issue (see https://github.com/jeromecoutant/mbed/commits/DEV_USB_STM32 from @jeromecoutant) but I have no idea wether a patch will be available soon or not.
Yes, I dug into the code and it’s not supported as yet. Was thinking of adding it myself if I can find the time inbetween development work for my clients (they come first before in-house projects). I think the STM32WL when it’s out for general release may put this further on the backburner.
Another option is to just put an equivalent Muratu system on a PCB but with an uprated STM32L4 that is fully supported. Cost is higher though but would be supported out of the box by MBED.
