Hello
I’m currently working on a project using mbed and have faced a technical challenge that I could use some help with.
I’m trying to interface a sensor with my mbed microcontroller, but I’m having trouble reading data from it. I’ve checked the wiring and verified that the sensor is functioning correctly. However, when I try to read data from the sensor using the mbed API, I’m not getting the expected results. I have checked Mbed OS - Arm Mbed OS support forum
info I’m using an mbed microcontroller model: Mbed LPC1768 and sensor model: DHT22 temperature and humidity sensor. I’ve reviewed the sensor’s datasheet and followed the instructions for reading data, but I’m still facing issues.
pls help .
Thank you
stevediaz
